Behringer BEQ700 7-Band Graphic Equalizer Effects Pedal
Brand:|Model: BEQ700|Part # 248-6098
Ultimate 7-band graphic equalizer designed to match the frequency range of bass guitars by allowing 7-band sound shaping and feedback elimination from 50 Hz to 10 kHz and with a powerful 15 dB boost/cut per band, it is ideally suited even from 5-string and 6-string bass guitars.
List Price$37.99
You Save34%
$24.99
Part # 248-6098
  • 7-band graphic equalizer designed specifically for the bass guitar, even 5 & 6-string instruments
  • Wide frequency range from 50 Hz to 10 kHz with a powerful 15 dB boost/cut per band
  • Shape your sound and eliminate feedback with 7 bands of equalization
  • Status LED for effect on/off and battery check
  • First-class electronic On/Off switch for noise-free operation
Do you find it hard to get the perfect sound from your bass? Maybe your bass seems to virtually disappear in some rooms; then again, it feels like a runaway locomotive in others? The problem's not your bass; you need an equalizer! The Behringer BEQ700 can resurrect your bass, providing total control over your tone, no matter what the performance situation. You can instantly improve the sound of your band from the bottom up, with the Behringer BEQ700.
Master of Tone
With 15 dB available boost or cut per band (that's a lot!), the BEQ700's seven frequency bands have been carefully optimized for EQing the bass guitar, even 5 and 6-string instruments. Of course, to make full use of the BEQ700's capabilities, it helps to first understand some basics about the frequency range of your axe.
The BEQ700 covers the audio spectrum from below 50 Hz to over 10 kHz, allowing you to effectively cut or boost specific frequencies that help focus your sound. Special attention has been paid to the critical midrange frequencies, which can either make or break your tone. Our Bass Equalization Guide offers tips that will have you sculpting the perfect bass sound in no time at all.
Understanding EQ
Most performers don’t have a clue about what good equalization can do for their sound. Maybe you’ve heard the old maxim, "Make a sine-wave to get really good sound," or "Make a smiley-face, that always works." Sadly, this qualifies as advice from the uninformed. Just as every room is different, every musical instrument is unique. Even guitars and basses made by the same manufacturer, using the same materials, on the same day can vary a great deal.
People provide a good example of this principal—although we are all similar, we don’t all wear the same size shoes, or even have the same color eyes. There is no one "perfect" equalization curve that fits every scenario; equalization is dynamic.
Applying EQ to the Bass
When frequencies from 20 Hz - 200 Hz are boosted or cut, the bass is affected dramatically, since sounds in this range are often felt, as well as being heard. Boosting frequencies within this range can increase the sensation of power and punch. Conversely, reductions in this range can weaken or muddy low frequency response.
The fundamental notes of most basses fall within the 100 Hz - 1000 Hz range. Even slight changes in this range can cause a tremendous variation in overall bass energy and impact, as the human ear is especially sensitive to this range. Boosting frequencies around 200 Hz often gives the bass warmth and body, without a loss of definition, while boosting frequencies in the 500 Hz to 1000 Hz range tend to make bass sounds brittle. Often, better EQ results can be achieved by reducing the frequency bands that are offending and by turning up the overall volume, rather than boosting one specific band.
How the specific frequency bands of the BEQ700 can shape your sound:
    • 50 Hz (sub-bass)
      Boost: To thicken up sub-bass content, which is mostly felt rather than heard
      Cut: To eliminate stage “rumble” and sub-bass content that can rob sound system power
    • 120 Hz (soft bass)
      Boost: To enhance the lower end of the bass spectrum
      Cut: To reduce the tendency of low frequency content to overwhelm a small room
    • 400 Hz (hard bass)
      Boost: To enhance the “hard” bass punch of fundamental tones
      Cut: To reduce punch for better linkage with the kick drum
    • 500 Hz
      Boost: or Cut: To control bass clarity and warmth
    • 800 Hz
      Boost: To add an aggressive edge to the overall bass sound
      Cut: For reducing somewhat nasal or horn-like content
   • 4.5 kHz
      Boost: To make the bass cut through the mix. Creates a more distinctive plucked tone
      Cut: To eliminate harshness
    • 10 kHz
      Boost: To bring out the upper harmonics and add edge to the overall bass tonality
      Cut: Apply a cut to reduce harsh high-frequency content or hiss
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output  impedance: 1k ohm • Power supply: 9V, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelBEQ700
  • Part Number248-6098
  • UPC736211843272
  • Product CategoryGuitar & Bass Effects Pedals
    (6 Reviews)
  • Weight0.85 lbs.
View similar products to the Behringer BEQ700 7-Band Graphic Equalizer Effects Pedal
in the Guitar & Bass Effects Pedals product category.
