CLEARANCE
248-6094_ALT_0
248-6094_ALT_1
Behringer BDI21 V-Tone Bass Amp Modeler / DI Box
Brand:|Model: BDI21|Part # 248-6094
So much more than a mere DI box, the BDI21 is also an analog modeling bass preamp/stompbox. We give you authentic V-TONE modeling technology capable of dialing up big vintage tube tones, funky slap sounds, crunchy distortions and everything in-between.
List Price$44.99
You Save33%
$29.99
Part # 248-6094
  • Analog modeling bass preamp/stompbox with DI recording output
  • Authentic tube emulation circuitry can be mixed with the direct bass signal via blend control
  • Ground lift switch eliminates typical ground loop problems
  • High-quality components and exceptionally rugged construction ensure long life
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
There are DI boxes...and then there's the V-TONE BASS BDI21—the feature-packed analog DI box built especially for bass.
Not Your Average DI Box
The BDI21 combines the features of an active DI (direct injection) box with our proprietary tube emulation circuitry. It’s like having a truckload of vintage tube amps right at your toes! The Blend control allows you to mix the amount of tube emulation you want with your direct bass signal. And if you don’t want to use the tube emulation feature, just step on the switch and the ADI21 functions as a superb active DI box.
So Easy to Use
With its dedicated DRIVE, TREBLE, BASS, LEVEL, and PRESENCE dials, the BDI21 DI box goes above and beyond, giving you vintage tube tones for some funked-up slap, gonzo overdrive and everything in-between. You can use the BDI21 as a recording output DI, with tube emulation, or as a standard active DI box, when running in bypass mode. The output is laid out on 1/4" TS or balanced, gold-plated XLR connectors. There's also a ground lift switch that eliminates typical ground loop hum problems. You can power this bad boy with a 9V battery or our PSU-SB DC power supply (not included).
Value
When it comes to DI boxes, you can go with simple injection, or plug into the BDI21 to add some badass tube-like fuel injection to your bass.
  • BrandBehringer
  • ModelBDI21
  • Part Number248-6094
  • UPC689076475242
  • Product CategoryGuitar & Bass Effects Pedals
    (1 Reviews)
  • Weight1.2 lbs.
View similar products to the Behringer BDI21 V-Tone Bass Amp Modeler / DI Box
in the Guitar & Bass Effects Pedals product category.
