BONUS ITEM INCLUDED
248-6554_ALT_0
248-6554_ALT_1
Behringer B912NEO Eurolive 1200W 12" Powered PA Speaker
Brand:|Model: B912NEO|Part # 248-6554
The new standard in low-frequency reproduction is here, with a 1,200 watt 12" subwoofer, the new Eurolive B912NEO by Behringer has it all from a 12" neodymium woofer to a 1.75" neodymium titaniumdiaphragm compression driver.
ORDER TODAY
Ships in 7-10 Business Days
List Price$599.99
You Save33%
$399.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6554
  • 1,200 watt sound reinforcement speaker system w/integrated mixer for live & playback applications
  • Ultra-compact and light weight plastic composite material provides excellent sound even at extreme
  • Powerful and light weight 12" neodymium woofer provides incredibly deep bass and acoustic power
  • Revolutionary Class-D amplifier technology: enormous power and incredible sonic performance
  • State-of-the-art 24-bit digital signal processor for ultimate system control
  • Digital crossover, phase and time correction for perfect driver alignment
  • Digital noise gate, low-cut filter, 2-band EQ, dynamic Contour filter
Behringer's EUROLIVE 12" 1,200 watt NEO Series active loudspeaker is destined to become the new standard in high-quality live sound reproduction. Packed with an incredible array of truly professional features, this brute provides extreme levels of low-end punch, with the kind of high-fidelity definition and clarity typically reserved for much larger systems. This powerful new speaker system outperforms its predecessors—and weigh 30% less!
Class-D Works its Magic
What’s the secret? This state-of-the art active loudspeaker is powered by custom-engineered Class-D amplifiers, which drive the low- and high-frequency transducers to its limits without even the slightest hint of distortion. Best of all, our Class-D amplifier uses switch-mode power supplies, which doesn’t need massive transformers and heat sinks, so it provides a much better power-to-weight ratio than many competing active systems. Put simply, this cool-running system is up to 30% lighter than its predecessors, making it ultra-easy to transport and set up. Our no-compromise design means you get solid punchy bass, along with powerful mids and pristine highs that will keep the party going all night long.
Digital Signal Processing
From the instant the signal enters the NEO system, the digital processor takes over, ensuring the highest possible signal integrity—and we're talking CLEAN! Much more than just selective EQ enhancement, the 24-bit DSP (Digital Signal Processor) circuitry analyzes the signal and intelligently applies specific filters to actually improve the sound quality. It’s like having a tiny sound guy inside each enclosure (with all the best gear), monitoring the input and output signals, dialing in the perfect EQ and constantly making subtle adjustments to the crossover, compressor/limiter and more.
Custom-Designed Transducers
Let's face it; the transducer (speaker) is the only part of a sound system you actually hear, so Behringer doesn't cut any corners. While some of their competitors are content to grab whatever they have on hand and plug them into their boxes, they build their transducers from scratch. Not only do they wind our own voice coils, they process the paper pulp into cones and even machine the frames and back plates. This enables them to control the quality, and frankly, make better components—like the neodymium woofers and 1.75" neodymium titaniumdiaphragm compression drivers we deploy in each and every NEO Series loudspeaker.
Power to Spare
Cutting-edge technology and high fidelity transducers are not all it takes to get your message across—you need power, and lots of it. At the heart of each of these systems is a bi-amped 1,200 watt engine capable of driving the speakers to their very limit, without the slightest hint of distortion. When it comes to pure output power, the EUROLIVE NEO Series loudspeaker will simply blow you away with its massive punch, smooth mids and articulate top-end!
Instant PA System
With just a single NEO loudspeaker system and one or two dynamic microphones, you can set up an instant sound system. The onboard mixer features a LEVEL control for each input and a dual-band master EQ, complete with an adjustable LOW CUT filter to help eliminate annoying breath pops and mic handling noise. An additional filter, which we call CONTOUR, allows you to select SPEECH (for enhanced voice intelligibility), or MUSIC for the broader frequency range required for the high-fidelity reproduction of music. And if you need more coverage, you can chain together as many as you like via the convenient LINE OUT XLR connector.
Marvelous Monitoring
When laid on their side, NEO Series loudspeakers tilt to the ideal angle for onstage monitor wedge applications. Hookup is simple, requiring only a single XLR cable from the monitor send on the mixing console and, of course, power. Additional monitors can be chained together via the XLR LINE OUT jack on the loudspeaker’s rear panel.
More Than Just a PA Loudspeaker...
NEO Series loudspeakers also make excellent onstage monitors for keyboards, acoustic guitars, or any line-level instrument for that matter. You can plug your instrument into MIC/LINE 1 and use the MIC/LINE 2 input to connect the monitor signal from the PA mixing console, so that you can also hear the other members of your band. This opens up lots of possibilities.
If you want to use more than two instruments, you will need a submixer (e.g. XENYX 1204) to mix down the signals. You will need a special adapter to convert a standard 1/4" TS cable to XLR, or a direct injection box such as our ULTRA-DI DI100.
Value
When it comes to serious bang for your buck, it's hard to beat the NEO Series—and the sound quality is second to none! For a rump-shaking romp into sonic wonderland, team up a pair of NEO Series loudspeakers with our amazing new active subwoofers, the B1500D-PRO or B1800DPRO. Be sure to check with local authorities to make sure you’re nowhere near a seismic fault. These babies really rock!
Specifications: • Output power (@ 8 ohms): Low frequency 800 watts RMS @ 1% THD, 1,200 watts peak; High frequency 50 watts RMS @ 1% THD, Low frequency 60 watts peak • Sensitivity: -40 dBu to +10 dBu • Input impedance: 27 ohms • Line Out: XLR balanced • Output impedance: 120 ohms • Frequency response: 45 Hz to 20 kHz • Dimensions: 26.0" H x 15.0 W x 15.5 D (660 x 380 x 395 mm) • Weight: 42 lbs. (19 kg).
  • Speaker TypeActive / Powered
  • Woofer Size12"
  • BrandBehringer
  • ModelB912NEO
  • Part Number248-6554
  • UPC705105164380
  • Weight41.71 lbs.
View similar products to the Behringer B912NEO Eurolive 1200W 12" Powered PA Speaker
