Behringer B812NEO Eurolive 1200W 12" 2-Way Powered Active PA Speaker
Brand:|Model: B812NEO|Part # 248-6620
Behringer's B812NEO is capable of handling up to 1,200 watts with its powerful 12" neodymium woofer, 1.75 state-of-the-art titanium-diaphragm neodymium compression driver, and Class D amplifier technology.
Ships in 7-10 Business Days
List Price$599.99
You Save33%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6620
  • High-power 1,260 watt 2-way PA sound reinforcement speaker system with integrated mixer for live and playback applications
  • Ultra-compact and light weight plastic composite material provides excellent sound even at extreme sound pressure levels (speaker weighs only 41 lbs.)
  • Extremely powerful and light weight 12" neodymium woofer provides incredibly deep bass and acoustic power
  • Revolutionary Class-D amplifier technology: enormous power, incredible sonic performance
  • State-of-the-art 1.75" titanium-diaphragm neodymium compression driver for exceptional high-frequency reproduction
  • Ultra-wide dispersion and large format exponential/conical horn with multi-cell aperture throat
Packed with an incredible array of professional features the Eurolive Series are destined to become the new standard in high-quality live sound reproduction. Put simply, these cool-running systems are up to 30% lighter than their predecessors, making them ultra-easy to transport and set up. Our no-compromise design means you get solid punchy bass, along with powerful mids and pristine highs that will keep the party going all night long.
Class-D Works its Magic
What’s the secret? These state-of-the-art active loudspeakers are powered by custom-engineered Class-D amplifiers, which drive the low- and high-frequency transducers to their limits without even the slightest hint of distortion. Best of all, our Class-D amplifiers use switch-mode power supplies, which don't need massive transformers and heat sinks, so they provide a much better power-to-weight ratio than many competing active systems.
Digital Signal Processing
From the instant the signal enters the NEO system, the digital processor takes over, ensuring the highest possible signal integrity—and we’re talking CLEAN! Much more than just selective EQ enhancement, the 24-bit DSP (Digital Signal Processor) circuitry analyzes the signal and intelligently applies specific filters to actually improve the sound quality. It's like having a tiny sound guy inside each enclosure (with all the best gear), monitoring the input and output signals, dialing in the perfect EQ and constantly making subtle adjustments to the crossover, compressor/limiter and more.
Custom-Designed Transducers
Lets face it; the transducer (speaker) is the only part of a sound system you actually hear, so we don't cut any corners. While some of our competitors are content to grab whatever they have on hand and plug them into their boxes, we build our transducers from scratch. Not only do we wind our own voice coils, we process the paper pulp into cones and even machine the frames and back plates. This enables us to control the quality, and frankly, make better components—like the neodymium woofers and 1.75” neodymium titanium diaphragm compression drivers we deploy in each and every NEO Series loudspeaker.
Power to Spare
Cutting-edge technology and high fidelity transducers are not all it takes to get your message across—you need power, and lots of it. At the heart of each of these systems is a bi-amped 1,200 watt engine capable of driving the speakers to their very limit, without the slightest hint of distortion. When it comes to pure output power, the EUROLIVE NEO Series loudspeaker will simply blow you away with its massive punch, smooth mids and articulate top-end!
Instant PA System
With just a single NEO loudspeaker system and one or two dynamic microphones, you can set up an instant sound system. The onboard mixer features a LEVEL control for each input and a dual-band master EQ, complete with an adjustable LOW CUT filter to help eliminate annoying breath pops and mic handling noise. An additional filter, which we call CONTOUR, allows you to select SPEECH (for enhanced voice intelligibility), or MUSIC for the broader frequency range required for the high-fidelity reproduction of music. And if you need more coverage, you can chain together as many as you like via the convenient LINE OUT XLR connector.
Marvelous Monitoring
When laid on their side, NEO Series loudspeakers tilt to the ideal angle for onstage monitor wedge applications. Hookup is simple, requiring only a single XLR cable from the monitor send on the mixing console and, of course, power. Additional monitors can be chained together via the XLR LINE OUT jack on the loudspeaker's rear panel.
More Than Just a PA Loudspeaker...
NEO Series loudspeakers also make excellent onstage monitors for keyboards, acoustic guitars, or any line-level instrument for that matter. You can plug your instrument into MIC/LINE 1 and use the MIC/LINE 2 input to connect the monitor signal from the PA mixing console, so that you can also hear the other members of your band. This opens up lots of possibilities.
If you want to use more than two instruments, you will need a submixer (e.g. XENYX 1204) to mix down the signals. You will need a special adapter to convert a standard 1/4" TS cable to XLR, or a direct injection box such as our ULTRA-DI DI100. When it comes to serious bang for your buck, it’s hard to beat the NEO Series—and the sound quality is second to none!
Audio Input Specifications: • XLR (servo-balanced): Channels 1 & 2 • Sensitivity: -40 dBu to +10 dBu • Input impedance: 27k ohms • Level control: Channels 1 & 2 • Max. input level: +22 dBu.
Audio Output Specifications: • Line out: XLR, balanced • Impedance: 120 ohms.
Overall System Specifications: • Output power (Low-frequency range): 800 watts RMS (8 ohms)/ 1,200 watts peak (8 ohms) • Output power (High-frequency range): 50 watts RMS (8 ohms)/60 watts peak (8 ohms) • Frequency response: 45 Hz to 20 kHz • Crossover frequency: 1.54 kHz • SPL: Max. 127 dB @ 1m • Tweeter: 1.75" neodymium titanium-diaphragm HF driver • Woofer: 12" neodymium LF transducer • Dynamic equalizer: Processor-controlled, dual parametric EQs • Dimensions: 26" H x 15" W x 15.5" D (660 x 380 x 395 mm) • Weight: 42 lbs. (19 kg).
  • Speaker TypeActive / Powered
  • Woofer Size12"
  • BrandBehringer
  • ModelB812NEO
  • Part Number248-6620
  • UPC705105164588
  • Weight41.8 lbs.
View similar products to the Behringer B812NEO Eurolive 1200W 12" 2-Way Powered Active PA Speaker
