Behringer B3030A TRUTH 6.75" Active Studio Monitor Each
Brand:|Model: B3030A|Part # 248-6462
Behringer created the perfect studio monitor the B3030A TRUTH monitor, with an ultra-high resolution 2" velocity ribbon transducer and a long-throw 6-3/4" long-throw woofer.
Part # 248-6462
  • Ultra-linear frequency response with individual frequency diagrams
  • Built-in 140 watt Bi-amp module with enormous power reserve
  • Ultra-high resolution, 2" velocity ribbon transducer for ultimate sound reproduction
  • Long-throw 6-3/4" woofer with deformation-resistant Kevlar cone and aluminum die-cast chassis for ultimate bass response
  • Controlled dispersion characteristics and extremely large "sweet spot" owing to the unique BEHRINGER wave guide technology
  • Active crossover network with 4th order Linkwitz-Riley filters
  • Adjustable to a wide range of acoustic conditions and subwoofer operation
Honesty
When it comes to your studio recordings, you want honesty. In fact, considering how important your art is, you should demand it! That's why the new B3030A Reference Monitor speaks nothing but the TRUTH. Oh, it still sounds great hooked up to your stereo or your video surround system, but it was really built with the studio in mind — where every note you play or sing is "under the microscope."
Built on a Legacy
Behringer's TRUTH B2030A and B2031A monitors have been so wildly successful that they've sold thousands upon thousands of them to some of the most critical ears on the planet. So, from the moment this project started, they knew these new speakers would have to be something really special, and indeed they are!
Years of R'n'D
For the past two years the Research and Development team has been on a mission to create the "perfect" studio monitor. Since the TRUTH B2031A had already become the industry standard, acoustic engineers decided to start there and see just how far they could push the envelope. They tried a variety of transducers and enclosure designs, along with existing and emerging technologies. When all the dust settled, they chose to deploy an ultra-high resolution, 2" velocity ribbon transducer and a long-throw, Kevlar-coned woofer in a deformation resistant, die-cast aluminum chassis.
Why Kevlar?
Behringer's glad you asked. Kevlar has an incredible strength-to-weight ratio — that's one reason it's used in bulletproof vests. Kevlar gives our LF transducer the strength to handle the extremely high energy levels required for distortion-free, chest-pounding bass. And since they have such low mass, Kevlar speaker cones also respond much more quickly than those made of paper, important for not only maintaining bass content integrity, but critical for midrange accuracy and definition. Our Kevlar transducers reproduce even the subtlest nuance of the low-frequency realm without muddying the midrange.
What's With the Funny-Looking Tweeter?
Ribbon tweeters bring a level of accuracy and sophistication to high-resolution studio monitors that was previously unattainable. They provide exceptionally wide horizontal dispersion (for a larger "sweet-spot"), while holding the vertical dispersion extremely tight. And since our ribbon transducer diaphragm is virtually weightless, it reacts instantaneously to changes in the high-frequency content. Now, not only do you hear the dulcet tones of a flute, you hear the breath flowing through it... You hear the wind chimes bouncing off each other... You can hear the fingernails on the nylon strings of a classical guitar...
Another reason why ribbon tweeters are so supremely accurate is their ability to reproduce frequencies far above our normal hearing range. Even though we can't hear these "ultrasonics," the lower harmonics they generate do affect the way we experience the stereo image. For instance, a 30 kHz signal is too high for us to hear, but we can hear its first sub-harmonic (15 kHz), second sub-harmonic (7.5 kHz), and third (3.75 kHz), etc. All these sub-harmonics combine with the primary sound to create stunning realism. Power to the People It takes quite a bit more than just a "bulletproof" woofer and a high-tech ribbon tweeter stuck inside a fancy box to make a studio monitor of this class. It also takes power — and lots of it! But even more importantly, that power has to be matched to the individual high and low-frequency transducers. While some of our competitors are content to stick whatever speakers they have on the shelf into haphazardly designed boxes and then strap on a one-size-fits-all amplifier package, we build every single component from the ground up.
We pack 110 watts of bi-amped technology (including a time- and phase-corrected active crossover) into every B3030A, ensuring that you have the enormous power reserves you’ll need to drive them really hard.
Power to the People
It takes quite a bit more than just a "bulletproof" woofer and a high-tech ribbon tweeter stuck inside a fancy box to make a studio monitor of this class. It also takes power — and lots of it! But even more importantly, that power has to be matched to the individual high and low-frequency transducers. While some of Behringer's competitors are content to stick whatever speakers they have on the shelf into haphazardly designed boxes and then strap on a one-size-fits-all amplifier package, every single component is built from the ground up.
Designed to Work in Your Environment
The ideal environment for listening is a room that is "flat," neither too reflective (echoes) nor too absorptive (where the sound is muffled). But since all rooms are not the same acoustically, all TRUTH monitors come equipped to function in a wide variety of situations. Switches are provided to adapt the monitor’s low- and high frequency characteristics for optimal performance specific to your listening environment.
Placement is also critical. Ideally, all loudspeakers should be placed away from walls to ensure proper bass response. But fear not, B3030A monitor features Room Compensation switches so you can place them against walls, or even in corners. Walls tend to enhance low-frequency content, and corners exaggerate bass even more, but your TRUTH monitor can be custom-tailored to provide honest bass response for your situation, with the simple flick of a switch or two.
Non-fatiguing, Wide "Sweet Spot"
While some of Behringer's competitor studio monitors have a highly focused "sweet spot" (the optimal listening position for a pair of loudspeakers), our wave-guide is designed to create a much more generous, broader listening zone. That means you won't wear a hole in the carpet in that one spot where everything sounds great.
You are free to move around inside the stereo image to find the ideal spot in the mix for subtle instrument or effects placement opportunities. You also won't suffer the ravages of "monitorfatigue- syndrome," an ailment that comes from listening to harsh highmids and treble content for hours on end. The new 2" velocity ribbon transducer, along with our proprietary wave-guide design, generates silkysmooth high-end that is non-fatiguing, even during those all-night mix-down sessions that can test your nerves.
Hearing is Believing
We could bore you to tears with all the technical jargon (if you really like that stuff, there’s a special treat at the end), but hearing the TRUTH will make you a believer. From the "bulletproof" bass of its Kevlar woofer to the silky top-end of its ribbon transducer, we think you'll agree that nothing in this class outperforms the B3030A monitor.
Specifications: • High frequency driver: 2" ribbon • Low frequency driver: 6-3/4" diameter Kevlar diaphragm • Amplifier output power: LF 50 watts RMS (4 ohms), 75 watts peak (4 ohms); HF 25 watts RMS (6 ohms), 35 watts peak (6 ohms) • Crossover type: Active, 4th order Linkwitz-Riley • Crossover frequency: 3.6 kHz • Frequency response: 50 Hz to 24 kHz • SPL: Max 113 dB SPL @ 1m (pair) • Dimensions: 12.50" H x 8.40 W x 8.33 D • Weight: 22 lbs.
  • Speaker TypeActive / Powered
  • Speaker Configuration2-Way
  • Woofer Size6-3/4"
  • BrandBehringer
  • ModelB3030A
  • Part Number248-6462
  • UPC4033653061421
  • Product CategoryStudio Monitors
  • Weight23.2 lbs.
View similar products to the Behringer B3030A TRUTH 6.75" Active Studio Monitor Each
in the Studio Monitors product category.
