Behringer B208D Eurolive Active 220W 8" 2-Way PA Speaker
Brand:|Model: B208D|Part # 248-6466
The Eurolive B208D, 220 watt 8" loudspeaker, provides a much better power-to-weight ratio than competing active speakers thanks to the revolutionary Class-D amplifier technology and internal switch-mode power supplies.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$269.99
You Save33%
$179.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6466
  • High-power 220-watt 2-way PA sound reinforcement speaker system for live and playback applications
  • Ultra-compact & light weight system delivers excellent sound even at extreme sound pressure levels
  • Revolutionary Class-D amplifier technology powerful, incredible sonic performance and light weight
  • Internal switch-mode power supply for noise-free audio and superior transient response
  • Integrated sound processor for ultimate system control and speaker protection
  • Extremely powerful 8'' long-excursion driver provides incredibly deep bass and acoustic power
  • State-of-the-art 1.35'' aluminum-diaphragm compression driver
Finally, great-sounding active loudspeakers that won't break your back or bank account! Thanks to our revolutionary Class-D amplifier technology and internal switch-mode power supplies, EUROLIVE D Series loudspeakers provide a much better power-to-weight ratio than competing active speakers. Put simply, you get all the power without the back-breaking weight. Due to the high-efficiency design, the B208D cranks out 220 of the cleanest, punchiest audio watts you've ever heard from a compact loudspeaker system. The integrated sound processor provides total system control, along with dependable protection of the LF and HF transducers, thanks to the built-in active high-pass filter, which virtually eliminate distortion — even at extreme operating levels. In addition, it features an Ultra-Low Noise (ULN) Mic/Line input with LEVEL control and a dedicated 2-band EQ (bass/treble) for easy control.
Class D Amplifier Technology Delivers High Power With Low Weight
Instead of operating relatively continuously like Class AB circuits, Class D amps switch on and off thousands of times per second, delivering power only when needed. In other words, the amplifier is either fully on or fully off, which significantly reduces the power losses in the output devices. This is easy in theory and complex in practice, which is why there are so many different Class D designs. Without boring you with terms like PWM Generation and Gate Drivers, let's just say that to realize the benefits of a Class D design requires compensating for a lot of potential problems that can cause audible distortion. Behringer didn't invent Class D technology, but their R&D Department has been working for years to perfect their own version with all the benefits of reduced weight and cool running, and none of the drawbacks. That's why they invested over a solid year of research time eliminating pitfalls like quantizing errors and excess dead time, selecting just the right switching frequency (and other equally tech-y terms). And spent an equally long time testing individual components to ensure they will stand up to the rigors of the real world.
When combined with switching-mode power supplies that replace heavy toroid transformers, our new designs provide more dynamic punch since the higher switching frequency reloads the supply's capacitors much faster. And, because they are so much more efficient, the D Series runs cooler and doesn't require huge, heavy heat sinks. The resulting speakers systems are much lighter, making them easy to transport and set up. Our no-compromise design means your D Series active loudspeakers will deliver full power and incredible fidelity all night long, with no need for rest cycles.
Instant PA System
With just a single D Series loudspeaker system and a microphone or MP3 player, you can set up an instant sound system. Thanks to the built-in preamp section, you just connect a dynamic mic and raise and lower the volume with the Level control. Plug in your sound source, place the speaker on a tabletop or stand, and power up. It's just that easy. And if you need more coverage, simply use the convenient LINK OUTPUT XLR connector to add more active loudspeakers.
Stereo Music System
You can even use two D Series enclosures for stereo playback of your MP3, CD or old-skool cassette deck without any additional hardware. Just plug the appropriate stereo "breakout" adapter into your deck's output jack and run the cables to the 1/4" inputs on each loudspeaker. Set the Level and EQ controls the same on both enclosures. Voilà, instant party!
Marvelous Monitoring
Thanks to their trapezoidal design, these cabinets can be laid on their side providing the ideal angle for onstage monitor wedge applications. Hookup is simple, requiring only a single XLR or 1/4" cable from the monitor send on your mixing console and, of course, power. Additional monitors can be chained together via the XLR LINK OUTPUT jack on the rear panel.
Custom-Designed Transducers
Let's face it; the transducers (woofers and tweeters) are the only part of a sound system you actually hear, so Behringer doesn't cut any corners. While some of their competitors are content to buy off-the-shelf transducers and plug them into their boxes, they custom-design and build our transducers from scratch. Not only do they wind our own voice coils, they process the paper pulp into cones and even machine our own backplates. This enables them to control the quality, and frankly, make better components, like the long-excursion LF transducers and state-ofthe- art 1.35" compression drivers we deploy in each and every EUROLIVE enclosure.
Low Frequency Response
The EUROLIVE D Series was built with extended low frequency handling in mind. With a tuned port, internally braced, injection molded enclosure, each model's custom designed LF transducer (woofer) really cranks out tight low end. Keep in mind that bass response varies according to LF transducer size, so the larger the speaker, the more bass you will be able to generate.
Accurate Non-Fatiguing Midrange and Treble
Even if your particular application doesn't include booming bass, you'll love the sheer accuracy of these loudspeakers. Over a year of design went into a exponential horn/aluminum dome compression driver combination that could do justice to loud hard rock or dance music — yet could also satisfy audiophiles with its musical timbre and attention to detail. For spoken word, singing or acoustical instruments, they are un-matched for being able to articulate complex harmonic details. In fact, many customers think it's the most natural-sounding speaker they've ever heard at anywhere near the price.
Processor Controlled Output
Dynamic processing is one of the best ways to maximize output without sacrificing sound quality. The D Series' built-in circuitry automatically adjusts program content, allowing the loudspeaker to operate at extreme levels. It accomplishes this by reducing bass output slightly as you approach the limit of the transducers. This frees up LF amp and transducer resources, so that higher overall volume can be realized. It's like having a tiny soundman inside each cabinet constantly monitoring and changing output parameters. By making subtle changes to the crossover frequency and the audio content, the system is able to crank out more sound — without the slightest hint of distortion.
Massive Power to Size Ratio
Cutting-edge technology and high-fidelity speakers are not all it takes to get your message across — you need power, and lots of it. At the heart of each EUROLIVE D Series loudspeaker are two high-current amplifiers with a total output of 200 watts for the B208D. They're capable of driving the speakers to their maximum with no distortion — and without speaker damage, thanks to active internal protection circuits. Put simply, they will astound you with their massive punch, smooth mids and articulate top-end!
Specifications: • Output power: LF 135 watts RMS (8 ohms), 160 watts peak (8 ohms); HF 38 watts RMS (8 ohms), 42 watts peak (8 ohms) • Frequency response: 65 Hz to 20 kHz • Crossover frequency 2.4 kHz • SPL: Max 113 dB SPL @ 1 m • Limiter: Optical • Dynamic Equalizer: Processor-controlled • Dimensions: 14.7" H x 8" W x 9.8" D (249 x 205 x 372 mm) • Weight: 14.7 lbs. (6.70 kg).
  • Speaker TypeActive / Powered
  • Woofer Size8"
  • BrandBehringer
  • ModelB208D
  • Part Number248-6466
  • UPC705105165585
    (1 Reviews)
  • Weight17.8 lbs.
View similar products to the Behringer B208D Eurolive Active 220W 8" 2-Way PA Speaker
