BONUS ITEM INCLUDED
248-6612_ALT_0
248-6612_ALT_1
248-6612_ALT_2
248-6612_ALT_3
248-6612_ALT_4
Behringer B205D Eurolive 5-1/4" Active 150W PA Monitor
Brand:|Model: B205D|Part # 248-6612
The new B205D, an active PA loudspeaker that is small and light enough to mount on a mic stand. But don't let the small size fool you—the B205D cranks out high-fidelity sound and comes loaded with features that will simply astound you!
List Price$299.99
You Save33%
$199.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6612
  • Multi-purpose, 150 watt, active speaker for vocal and keyboard monitoring, multi-media, and more
  • Revolutionary Class-D amplifier technology: enormous power, incredible sonic performance and light
  • 5-1/4" premium-quality, full-range neodymium driver
  • Ultra-low noise 3-channel mixer with 3-band EQ
  • 2 "Invisible" mic preamps with phantom power for condenser microphones and 1 instrument-ready input
  • Dedicated stereo input for keyboards, MP3, CD, etc.
  • XLR "through" connector with mic/line switch for linking more B205Ds
Frequently Bought Together
What if you could mount your personal monitor on a mic stand and point it right at your face—and what if it sounded really good? What if it sounded so good it could be used as your main PA system for more intimate gigs and meetings? Say hello to the new B205D, an active PA loudspeaker that is small and light enough to mount on a mic stand. But don't let the small size fool you—the B205D cranks out high-fidelity sound and comes loaded with features that will simply astound you! Thanks to our revolutionary Class-D amplifier technology and internal switch-mode power supplies, not only do B205D loudspeakers sound great, they weigh considerably less than most competing active speakers. They pump out 150 of the cleanest, punchiest Watts you've ever heard from a compact loudspeaker, and you can link additional active loudspeaker systems via the handy THRU socket. A built in mixer provides three input channels, including a switchable instrument-ready input (no DI required), and also features a dedicated 3-band EQ (bass/mid/treble) for simple, yet effective tonal control.
Put the Sound Where You Want It
Space limitations often make it impossible to place full-sized monitor wedges where they can do the most good—and passive monitors require lots of external amplifiers and processing gear to function properly. All this adds up to even more gear to move, and if you don’t know what you’re doing, you can easily damage passive monitors by applying too much, or even worse, too little power to them. With the B205D we’ve taken all the guesswork out, giving each loudspeaker its own 150 watt, Class-D amplifier specifically designed as the perfect mate for the custom-engineered 5.25" neodymium driver.
Say Goodbye to Back-breaking Floor Wedges
By using an internal switch-mode power supply, we reduced the weight of the B205D to a mere 7.0 lbs. (3.2 kg). This means that instead of bringing in your old passive floor wedges one-at-a-time, you can carry all your monitors in one trip—without even breaking a sweat! They are small enough to mount on mic stands (each speaker includes a special mic stand integration system), on a tabletop, or they can be placed directly atop a piano or electronic keyboard.
Class-D Technology Delivers High Power, Low Weight
Instead of operating relatively continuously like Class AB circuits, Class-D amps switch on and off thousands of times per second, delivering power only when needed. In other words, the amplifier is either fully on or fully off, which significantly reduces the power losses in the output devices.
When used in conjunction with switching mode power supplies, our Class-D amplifiers provide tremendous dynamic punch and superior fidelity. The resulting speakers systems are much lighter, making them easy to transport and set up. Our no-compromise design means your B205Ds deliver full power with incredible fidelity all night long, without the need for rest cycles.
Custom-Engineered Drivers
Let’s face it, the drivers (otherwise known as speakers) are the only part of a sound system you actually hear. So when it comes to ours, we don’t cut any corners. While some of our competitors outsource theirs, we custom-design and build our speakers from scratch. We wind our own voice coils, process the paper pulp into cones and even machine our own speaker back plates and frames. This enables us to control the quality, keep production costs down and frankly, to make better components. The premium-grade 5.25" neodymium driver was designed specifically and optimized solely for use in the B205D.
Instant PA System
With just a single B205D loudspeaker system and a microphone, you can set up an instant, high-quality sound system. Thanks to the built-in preamp section, you just connect a dynamic mic and raise and lower the volume with the LEVEL control. Plug in your sound source (CD or MP3 player), place the speaker on a tabletop or mic stand and power up. It’s just that easy. And if you need more coverage, you can chain together as many as you like via the convenient LINK OUTPUT XLR connector.
Stereo Music System
You can even use two B205Ds for stereo playback of your MP3, CD or cassette deck without any additional hardware—pretty cool for playing background music or making announcements. Just plug the appropriate stereo "breakout" adapter (not included) into your deck’s output jack, run one cable to each loudspeaker and set the Level and EQ controls the same on both B205Ds. Voilà, instant party!
Value
The EUROLIVE B205D provides highquality sound, tremendous functionality and versatility for very little dough. Best of all, since the B205D is so compact and lightweight, making it easy for you to load in or out at the gig. Compare the B205D to the competition and you’ll own BEHRINGER with money to spare!
  • Speaker TypeActive / Powered
  • ConfigurationStage Monitor
  • Woofer Size5-1/4"
  • BrandBehringer
  • ModelB205D
  • Part Number248-6612
  • UPC705105158686
    (4 Reviews)
  • Weight15.3 lbs.
View similar products to the Behringer B205D Eurolive 5-1/4" Active 150W PA Monitor
