Behringer B2030A 2-Way Active Reference Studio Monitor Each
Brand:|Model: B2030A|Part # 248-6036
Despite its small size, the TRUTH B2030A can achieve a peak output level in excess of 113 dB SPL, powered by separate 80 and 35 watt built-in amplifiers with an active crossover.
List Price$224.99
You Save33%
$149.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6036
  • Ultra-linear frequency response from 50 Hz to 21 kHz with individual frequency diagrams
  • Built-in 75- and 35-Watt power amps with enormous power reserve
  • Ultra high-resolution ferrofluid-cooled tweeter
  • Active crossover network with 4th order Linkwitz-Riley filters
  • Adjustable to a wide range of acoustic conditions and subwoofer operation
  • Separately controlled limiter for low and high frequency overload protection
  • Magnetic shielding allows placement near computer monitors
The TRUTH B2030A has all of the great features of an active TRUTH monitor packed in a compact cabinet! It's a high-resolution, active 2-way reference studio monitor that is perfect for near-field monitoring applications: from small mixing environments to multi-channel surround setups.  Despite its small size, the TRUTH B2030A can achieve a peak output level in excess of 113 dB SPL. Powered by separate 80 and 35 watt built-in amplifiers with an active crossover, this monitor provides ultra-linear frequency response from 50 Hz to 21 kHz. A long-throw 6-3/4" woofer with a special polypropylene diaphragm delivers smooth, deep bass, while an extremely high-resolution HF driver delivers highs that are crystal-clear and full of detail. The unique BEHRINGER wave guide and the extremely low-distortion crossover network produce an absolutely linear phase response with excellent sound dispersion and stereo imaging. The B2030A is equipped with servo-balanced inputs on XLR and 1/4" TRS connectors to handle a variety of audio sources. Thanks to its compact size and magnetic shielding, the TRUTH B2030A can be placed near video monitors, computer displays, or digital audio workstations. The B2030A is delivered with individual measurement diagram.
We Call it a Speaker Graduation Diploma
After final assembly, each  B2030A spends up to a half hour with a Calibration Engineer being  meticulously tweaked to ensure ultra-linear frequency response. When you buy a TRUTH B2030A monitor, you're truly getting a hand-calibrated unit. We ship a calibration certificate with each B2030A that shows the actual frequency response of your monitor, as tested at the time of manufacture. After all these rigorous tests, only then is the speaker granted its own Graduation Diploma.
Rock-Solid Bass
Bookshelf-style home stereo speakers can really fool you when it comes  to bass output, mainly because they are not designed for critical  listening applications. That’s why recording engineers and producers listen to projects through studio reference monitors or studio-grade  headphones. The B2030A’s long-throw 6.75" polypropylene-diaphragm woofer delivers smooth, deep bass all the way down to 50 Hz. Bass content that isn’t exaggerated, as it can be in home speaker systems. Rock-solid bass that is an honest representation of the recorded sound, full of subtle nuance; the sound of fingers on the strings, or the rush of air through the long pipes of a cathedral organ, etc.
Non-Fatiguing, Wide “Sweet Spot”
B2030A's HF (High Frequency)  content comes courtesy of an ultra high-resolution 0.75"  ferrofluid-cooled tweeter mounted on our proprietary wave-guide. While some of our competitor's studio monitors have a highly focused "sweet  spot" (the optimal listening position for a pair of loudspeakers), our wave-guide is designed to create a much more generous, broader listening zone. That means you won’t wear a hole in the carpet in that one spot  where everything sounds great. You are free to move around inside the stereo image to find the ideal spot in the mix for subtle instrument or effects placement opportunities. You also won't suffer the ravages of "monitor fatigue-syndrome," an ailment  that comes from listening to harsh high-mids and treble content for hours on end, even during those all-night mix-down sessions that can  really test your nerves.
Suited for All Placements
Ideally, all loudspeakers should be placed away from walls to ensure  proper bass response. But fear not, B2030A monitors feature Room  Compensation switches so you can place them against walls, or even in  corners. Walls tend to enhance low-frequency content, and corners  exaggerate bass even more, but your TRUTH monitor can be custom-tailored  to provide honest bass response for your situation, with the simple  flick of a switch or two.
  • Speaker TypeActive / Powered
  • Speaker Configuration2-Way
  • Woofer Size6-3/4"
  • BrandBehringer
  • ModelB2030A
  • Part Number248-6036
  • UPC689076748278
  • Product CategoryStudio Monitors
    (1 Reviews)
  • Weight22.3 lbs.
View similar products to the Behringer B2030A 2-Way Active Reference Studio Monitor Each
in the Studio Monitors product category.
