248-6832_ALT_0
248-6832_ALT_1
Behringer B1200D-PRO Eurolive 12" PA Subwoofer 500 Watt
Brand:| Model: B1200DPRO
Behringer's powered 15" and 18" powered subwoofers are among the most popular in the world. You may even own some yourself. What if your venue or application requires a smaller system, but still needs the warmth, richness, and impact that only a great sub can provide? Enter the B1200D-PRO 12" 500W powered subwoofer!
  • High-performance 500 watt powered subwoofer for PA applications
  • Powerful 12" long-excursion transducer with high temperature voice coil
  • State-of-the-art 500 watt Class-D amplifier with comprehensive over-excursion, thermal and clip limit protection
  • Built-in active stereo crossover provides high-pass filtered outputs for full-range loudspeakers
  • Tunable and switchable Bass Boost plus Phase switch for ultimate low-frequency performance
248-6832
Weight: 46.8000 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
List Price$449.99
You Save33%
$299.99
Part # 248-6832
Like their world-renowned big brothers, the B1500D and B1800D, Behringer's new B1200D-PRO packs the same feature set and reliability into a smaller package. Armed with a 500 watt Class-D amplifier and a host of truly professional features, these little brutes crank out tons of tight, low-end punch - with the definition and clarity typically reserved for much larger systems.
What is Class-D Technology?
Instead of operating relatively continuously like Class AB circuits, Class-D amps switch on and off thousands of times per second, delivering power only when needed. The amplifier is either fully on or fully off, which significantly reduces power losses from the output devices given off as heat. Less heat means Class-D amps don’t need massive heat sinks, and that means they're lighter. However, the amplifier in Behringer's B1200D-PRO still provides all the dynamic punch and fidelity you’d expect from a much larger, more expensive subwoofer.
Custom-Designed Transducers
The transducers (woofers and tweeters) are the only part of a sound system to actually translate electrical energy into acoustic energy you actually hear, so Behringer never cuts corners, and they never just grab whatever happens to be on the shelf. They custom-design each transducer to be the perfect match for both the amplifier and the application. They wind the voice coils, process the paper pulp into cones and even machine their own backplates. This enables Behringer to control the quality, and frankly, make better components. The 12" long-excursion, low-frequency transducer was designed specifically for use in the Eurolive B1200D-PRO.
Take Control
The B1200D-PRO features balanced XLR inputs and outputs, as well as balanced XLR Thru jacks for connecting additional enclosures. A Boost Frequency knob lets you boost any frequency between 45 Hz and 90 Hz. Then just flick the Boost switch to give your selected frequency a +10 dB boost. There is also a High Cut dial that controls the upper-corner frequency for the internal amplifier without affecting Thru A/B signals. A Level knob controls the input gain, and the Phase switch reverses the output phase to compensate for frequency cancellation between the subwoofer and satellite speakers. LEDs show operational status at a glance including power, signal present and input overloads.
Value
Plenty of power, light weight, amazing sound, rugged durability and affordability; you get it all with the Eurolive B1200D-PRO. Plus, it's backed up with one of the best warranty programs in the industry, a full 3 years!
Specifications: • Maximum output power: 500 watts • Frequency response: 60 Hz - 130 Hz (-10 dB), 45 Hz - 180 Hz (+/-3 dB) • S/N ratio (20 Hz to 20 kHz): >100 dB • SPL: 122 dB max • Dimensions: 17.0" x 14.8 x 16.7 (432 x 375 x 423 mm) • Weight: 43.1 lbs. (19.5 kg).
  • Speaker TypeActive / Powered
  • ConfigurationSubwoofer
  • Woofer Size12"
  • BrandBehringer
  • ModelB1200DPRO
  • Part Number248-6832
  • UPC4033653022156
    (1 Reviews)
  • Weight46.8000 lbs.
View similar products to the Behringer B1200D-PRO Eurolive 12" PA Subwoofer 500 Watt
Behringer B1200D-PRO Eurolive 12" PA Subwoofer 500 Watt is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Best small sub for th moneyPurchased this to go with a couple QSC K10 tops. I have small group, vocals, acoustic guitars Djembe and bass. We wanted a little something to add some bottom end and this thing fit the bill. We are not a loud group but we want high quality, full spectrum sound and this subwoofer fit the bill. The thing sounds great, easy to transport, quick to set up. Behringer is very under rated IMO - I've had a bunch of their stuff and never had an issue with any of it. I did have a chance to crank it up with some music running through the PA and in a small club (maybe 50 - 60) people this thing will thump your chest!
Date published: 2014-11-18
  • 2015-03-04T07:09CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_248-6832, PRD, sort_mostRecent
Customer projects that include: Behringer B1200D-PRO Eurolive 12" PA Subwoofer 500 Watt
