Behringer AMP800 4-Channel Stereo Headphone Amplifier
Brand:|Model: AMP800|Part # 248-6026
The compact, flexible AMP800 by Behringer can power up to eight pairs of headphones and up to 2 different stereo mixes.
List Price$104.99
You Save33%
$69.99
Part # 248-6026
  • Ultra-compact 9.5" headphone amplifier system for studio and stage applications
  • 4 totally independent stereo high-power amplifier sections
  • Highest sonic quality with virtually all types of headphones even at maximum volume
  • Phones Level control plus accurate 6-digit LED output meter per channel for easy level monitoring
  • Accurate 6-digit LED main input meter for precise level indication of both line inputs
  • Parallel Link Output allows cascading of several headphone amplifiers
If you're tracking more than one musician at a time, or if everyone in a group wants to listen to a playback, you need a monitor distribution system. The compact, flexible AMP800 can power up to eight pairs of headphones and up to 2 different stereo mixes.
Altogether Now
The AMP800 features four totally independent stereo high-power amplifier sections, each with dual outputs. You can use the phones level control plus the accurate 6-digit LED output meter per channel for easy level monitoring. There are 2 balanced stereo main inputs with independent Level and Balance controls for individual mixes, selectable for all 4 headphone amplifiers.
If you must accommodate more than eight listeners, a parallel Link Output enables cascading of several AMP800s. Long-term reliability is guaranteed thanks to high-quality potentiometers and illuminated switches, and our ultra low-noise audio operational amplifiers provide outstanding sound performance. In addition, all Mini Series models can be stacked to create an ultra-compact signal processing solution.
Great Sound, Great Value
When a recording session calls for everyone's heads—and ears—to be in the game, the AMP800 is a real lifesaver. Hearing is believing.
Input
 • Type: 1/4" TRS connector, balanced
 • Impedance: Approx. 20K ohm balanced, approx. 10K ohm unbalanced
 • CMRR: 40 dB typ. @ 1 kHz
Phones Out
 • Type: 1/4" TRS connector, stereo
 • Impedance: Min. 100 ohms
 • Max output level: +13 dBu @ 100 ohm load
Amplifier
 • Max. output level: +21 dBm/124 mW (100 ohm load)
 • Min output impedance: 47 ohms
System Specifications:
• Frequency response: 10 Hz to 120 kHz, -3 dB
• Dynamic range: 108 dB, 10 Hz to 22 kHz (100 ohm load)
• Distortion: 0.007% typ. (100 ohm load)
• Crosstalk: <80 dBu @ 1 kHz
• S/N ratio: 10 Hz to 22 kHz <95 dB @ 0 dBu, a-weighted
• Power supply: External power supply, 9V~ /750 mA
• Mains voltage: 120V~, 60 Hz
• Power consumption: 11 watts
• Dimensions: Approx. 1.89 H x 9.55" W x 4.72" D (48 x 242.6 x 120 mm)
• Weight: Approx. 1.09 lbs. (0.495 kg).
  • BrandBehringer
  • ModelAMP800
  • Part Number248-6026
  • UPC689076750479
  • Product CategoryHeadphone Amplifiers
    (3 Reviews)
  • Weight2.9 lbs.
View similar products to the Behringer AMP800 4-Channel Stereo Headphone Amplifier
in the Headphone Amplifiers product category.
