Behringer AM400 E-Acoustic Modeler Effects Pedal
Brand:|Model: AM400|Part # 248-6618
The AM400 effect pedal by Behringer allows you to choose between four acoustic models: Standard, large, piezo, and bright. But the real secret weapon is Behringer's real sound modeling technology (RMS) can accurately simulate environmental acoustics.
  • Achieve realistic acoustic guitar modeling using any electric guitar
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • 4 authentic acoustic simulations: standard, large, piezo and bright with built-in reverb, optimized for acoustic-guitar simulation
  • 2 individual outputs enable easy switching between electric and acoustic guitar sounds when using 2 separate amps
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
Transform your favorite electric guitar into a full-bodied acoustic without slowing down your shows momentum with the new AM400 Acoustic Modeler.
Just select one of the four models and use the dedicated resonance, level, and attack controls to dial in your ultimate acoustic guitar tone. The AM400 even has its own onboard reverb, custom-tailored to add the perfect finishing touch to your new acoustic sounds.
Thanks to its OUT and DIR OUT jacks, the AM100 functions very much like an A/B box. Just use the DIR OUT to send your unprocessed electric guitar signal to your onstage amp, and the OUT jack to send the processed acoustic signal to the main/monitor mixer(s). Need to rock? Your electric (both the guitar and the amp) is just a toe-tap away.
A status LED lets you know when the AM400 is activated, and you can power it with either a 9V battery or our PSU-SB DC power supply (not included). A top-quality on/off switch maintains excellent signal integrity in bypass mode.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Direct out connector: 1/4" TS • Direct out impedance: 1k ohm • Power supply: 9 VDC, 100 mA, regulated (sold separately) • Power consumption: 30 mA • Dimensions: Approx. 2-1/4" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelAM400
  • Part Number248-6618
  • UPC4033653053884
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.88 lbs.
View similar products to the Behringer AM400 E-Acoustic Modeler Effects Pedal
in the Guitar & Bass Effects Pedals product category.
