Behringer ADA8000 Ultragain Pro 8-Ch A/D & D/A Converter
Brand:|Model: ADA8000|Part # 248-6020
Behringer's ADA8000 is a high-end 8-channel A/D & D/A converter with premium mic preamplifiers and ADAT® interface.
Part # 248-6020
  • Ultra high-quality 8-channel A/D & D/A converter for any digital recording/mixing environment
  • 8 new state-of-the-art, studio-grade IMP Invisible Mic Preamps
  • Phantom power on all microphone inputs
  • The perfect expansion for BEHRINGER’s digital mixing console DDX3216
  • High-end 24-bit A/D and D/A converters for ultimate signal purity
  • Processes 44.1 and 48 kHz sample rates
Need to convert a digital signal to analog, or vice versa? The ADA8000 digital converter is sublimely easy to operate and fits neatly into a single rack space. The integrated A/D and D/A converters ensure optimal signal conversion without any distortion or signal deterioration.
The Basics
The ADA8000 is a state-of-the-art 8-channel A/D (Analog to Digital) and D/A converter with 8 built-in IMP (Invisible Microphone Preamps) microphone preamps. You can plug in your favorite mics (ADA8000 even includes +48 V phantom power for studio-grade condenser mics) and record directly to your multitrack or computer-based recorder, thanks to the built-in ADAT® interface. Conversely, the ADA8000 can also be used to convert digital signals, from soundcards and other multitrack devices, back into analog audio.
The Technical Stuff
Signal conversion in the ADA8000 can take place at either 44.1 or 48 kHz with 24-bit resolution. The ADAT® inputs and outputs can be operated independently, as long as there is an identical wordclock signal. Frequency range is an ultra-wide 10 Hz to 21 kHz at a 48 kHz sampling rate.
The Ins and Outs
Connections are provided for balanced XLR and 1/4" TRS, as well as unbalanced 1/4" TS inputs. Line Out connectors provide either balanced or unbalanced connectivity. Digital I/O is handled via a TOSLINK optical socket, which supports up to eight (8) channels of data.
You can trust all your digital ones and zeros to the ADA8000, at an ultra-affordable price that will amaze you.
Mic Inputs
• Type: Electronically balanced discrete input circuitry
• Gain range: +10 to +60 dB
• Max input level: +6 dBu @ +10 dB gain for 0 dBFS
• Impedance: Approx. 2K ohm balanced
• Phantom power: +48V switchable
Line Inputs
• Type: 1/4" TRS connector, electronically balanced, discrete input circuitry
• Impedance: Approx. 20K ohm balanced, approx. 10K ohm unbalanced
• Gain range: -10 to +40 dB
• Max input level: +26 dBu @ -10 gain for 0 dBFS
Line Outputs
• Type: XLR, electronically balanced
• Impedance: Approx. 500 ohm balanced, approx. 250 ohms unbalanced
• Max output level: +16 dBu @ 0 dBFS
System Specifications
• Frequency range: 10 Hz to 21 kHz @ 48 kHz sample rate
• THD: <0.01%
• Crosstalk: ≤86 dB
• Dimensions: 1-3/4" H x 19" B x 8-1/2" T
• Weight: Approx. 2.3 kg
  • BrandBehringer
  • ModelADA8000
  • Part Number248-6020
  • UPC4033653030212
  • Product CategoryA/D & D/A Converters
    (1 Reviews)
  • Weight7.6 lbs.
View similar products to the Behringer ADA8000 Ultragain Pro 8-Ch A/D & D/A Converter
in the A/D & D/A Converters product category.
