Behringer ACX1800 180W 2-Ch Acoustic Instrument Amp
Brand:|Model: ACX1800|Part # 248-6014
The ACX1800 by Behringer is an 180 watt 2-channel stereo acoustic instrument amplifier with dual FX and FBQ feedback detection.
Ships in 7-10 Business Days
List Price$524.99
You Save33%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6014
  • Powerful 180 watt, 2-channel stereo amplifier for acoustic instruments and vocals
  • 2 original 8" BUGERA dual-cone speakers for ultimate sound reproduction
  • 2 integrated, 24-bit digital FX processors each with 16 awesome effects programs
  • Revolutionary FBQ Feedback Detection System instantly reveals critical frequencies
  • 2 dedicated instrument and microphone channels with separate Gain, Compressor and FX controls
  • Individual 9-band graphic EQ on each channel for awesome sound shaping
These days, going "unplugged" still involves plugging into something. Make the sweet sounds of your acoustic guitar and voice big enough to cut through the clink of coffee cups and casual chit-chat with the ULTRACOUSTIC ACX1800.
The Ins and Outs
The 180 watt ACX1800 features two channels: one with a single 1/ 4" input jack and a second with a 1/4" input and XLR input, making it the ideal amp for a one-person show with an acoustic guitar and a mic for vocals. Just turn the GAIN dial to determine the levels of each channel.
On the back panel, you will find a stereo RCA input for plugging in a CD player. If you're just getting started as a guitarist, this is a great way to play along with your favorite tunes. Or, if you're playing an extended set, you can use the CD IN section to provide music during breaks. Two XLR LINE OUT jacks send a signal directly to a mixing board, and you can connect an external effects processor via the 1/4" INST INS SEND and RETURN jacks.
Switch it Up
The ACX1800 features myriad audio solutions at the touch of a button. Both channels feature a 7-band EQ equipped with Behringer's FBQ Feedback Detection System for instant feedback elimination. You also get a 24-bit FX processor per channel featuring 16 incredibly presets such as reverb and delay. We also include a footswitch for remote activation of the effects.
The instrument channel (on the left) features a PHASE switch that reverses the phase, a function that can eliminate the feedback common in acoustic guitar pickups. Both channels feature a TUNER switch that silences the speaker so you can tune your guitar via an external tuning device, which can be connected directly to the amp via the TUNER OUT 1/4" jack on the back panel.
Speaker Talk
Two original 8" BUGERA dual-cone speakers project your sound with the utmost integrity. These beautifully voiced speakers are made 100 percent in-house. We even grew the trees that became the pulp used for the cones! Every step of this incredible amplifier's creation was overseen by Behringer's quality control.
Big Sound, Small Package
The ultra-portable ACX1800 is the perfect way to quickly and easily bring a beautiful solo acoustic performance to a small venue. Plus it looks like a handsome piece of furniture! See how the ACX1800 can bring your mellow moods to a bigger audience.
 • Instrument in: 1/4" TS unbalanced
 • Input impedance: 10M ohm
 • Mic in: XLR balanced
 • Input impedance: 4k ohm
 • Line in: 1/4" TRS balanced
 • Input impedance: 40k ohm
 • Inst. insert return: 1/4" TS unbalanced
 • Input Impedance: 220k ohm
 • Mic insert return: 1/4" TS unbalanced
 • Input Impedance 220k ohm
 • CD input: RCA
 • Input Impedance >10k ohm
 • Line out: XLR balanced
 • Output impedance: 4.3k ohm
 • Max. output level: >24 dBu
 • Inst. insert send: 1/4" TS unbalanced
 • Output impedance: 100 ohm
 • Max. output level: >18 dBu
 • Mic insert send: 1/4" TS unbalanced
 • Output impedance: 100 Ohm
 • Tuner out: 1/4" TS unbalanced
 • Output impedance: 33k ohm
 • Max. output level: >6 dBu
Digital Processing
 • Converters: 24-bit sigma-delta, 64/128-times oversampling
 • Sampling rate: 40 kHz
Power Supply
 • Mains voltage: 120 V~, 60 Hz
 • Power consumption max.: 265 watts
 • Mains connection: Standard IEC receptacle
Loudspeaker Specifications
 • Type: 2 x 8"
 • Model: BUGERA™ dual cone speakers
 • Impedance: 4 ohm
 • Power handling 60 watts
System Specifications
 • Power rating 2 x 90 / 2 x 4 ohms
 • Dimensions: 16.8" x 20.7" x 9.5" (427 x 526 x 242 mm)
 • Weight 40.6 lbs. (18.4 kg)
  • BrandBehringer
  • ModelACX1800
  • Part Number248-6014
  • UPC689076751278
  • Product CategoryAcoustic Instrument Amplifiers
  • Weight49 lbs.
View similar products to the Behringer ACX1800 180W 2-Ch Acoustic Instrument Amp
in the Acoustic Instrument Amplifiers product category.
