Behringer AB200 Dual Programmable Footswitch
Brand:|Model: AB200|Part # 248-6008
Behringer's AB200 is a universal, ultra-compact 2-channel footswitch, an ideal accessory for stage and studio applications.
Part # 248-6008
  • Ultra-compact and universal 2-channel footswitch for stage and studio applications
  • Usuable for all products with external control functions
  • Easily switch between two input signals into one output or vice versa
  • Relay switching technology for ultra-high impedance and signal integrity
  • Dedicated LED indicators for precise status control
  • Combine multiple AB200's together by using the side-mount interlock
Use it on gear featuring external control functions such as guitar amps, keyboards, rhythm machines, lighting products, and so on. You can easily switch between two input signals into one output or vice versa (e.g. switch between two guitars using one amplifier or two amplifiers with one guitar). Latching/non-latching modes are selectable for both channels: Non-latch mode momentarily engages the switch while you hold down the pedal; Latch mode changes the On/Off status each time you press the pedal. We've relied on relay switching technology for ultra-high impedance and highest signal integrity. There are dedicated LED indicators for precise status control, and you can combine multiple AB200s by using the side-mount interlock. You will need one 9V battery for operation (not included).
Specifications: • Input 1/2 connector: 1/4" TS • Input 1/2 impedance: Relais hard bypass • Output A/B connector: 1/4" TS • Output A/B impedance: Relais hard bypass • Battery: 9V type 6LR61 • Power consumption: <30 mA • Dimensions: Approx. 1-4/5" H x 5-1/4" W x 3-1/2" D • Weight: Approx. 0.62 lbs. (0.28 kg).
  • BrandBehringer
  • ModelAB200
  • Part Number248-6008
  • UPC4033653051484
  • Product CategoryFootswitches
    (2 Reviews)
  • Weight0.7 lbs.
View similar products to the Behringer AB200 Dual Programmable Footswitch
in the Footswitches product category.
