B&C DE750-8 2" Titanium Horn Driver 8 Ohm 4-Bolt
Brand:|Model: DE750-8|Part # 294-614
The B&C DE750 2" titanium driver delivers smooth response, very high efficiency, and outstanding articulation.
ORDER TODAY
Ships in 7-10 Business Days
List Price$462.38
You Save40%
$277.43
Part # 294-614
  • Titanium dome with mylar surround combines stiffness with excellent damping
  • 3" edgewound flat aluminum wire voice coil
  • Copper shorting ring lowers distortion and smooths response
  • Delivers smooth response, very high efficiency, and outstanding sonic properties
  • Compares to the best 2" drivers available
The B&C Speakers DE750-8 is a premium 2" high frequency compression driver. The DE750's low mass titanium dome is supported by a rugged and acoustically neutral Mylar surround; a 3" edgewound flat aluminum wire voice coil is bonded to the diaphragm with high temperature adhesives. This advanced diaphragm assembly is combined with a very high flux density ceramic magnet assembly which includes a copper shorting ring. Recommended for low crossover frequencies.
Specifications: • Power handling: 80 watts RMS/160 watts program above recommended crossover of 800 Hz/12 dB slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-18,000 Hz • SPL: 108.5 dB 1W/1m • Dimensions: 7.1" diameter x 3.5" depth • Net weight: 13.9 lb. • Replacement diaphragm available.
B&C Speakers' line of compression drivers is the result of a continuous research effort, dedicated to refine every component in the structure, and their overall balance. Diaphragms are made of titanium, mylar, or polyimide, in order to get the required results in efficiency and bandwidth. Their shape and structure is mathematically evaluated well before building the first prototype. Afterwards, their performance is tested with methods that range from modal analysis to laser vibrotomy.
All voice coils are of the edgewound ribbon type, and made of aluminum to reduce mass and achieve the best electro-acoustic performance. The magnet assembly is designed and optimized with up-to-date software for Finite Element Analysis (FEA) and complemented, where needed, by a copper cap to improve frequency extension and linearity. Equal care is taken in the design of phase plugs, whose role in enhancing performance and reducing distortion artifacts is critical for compression drivers. The precision and transparency of B&C compression drivers is constantly improved by the progress in acoustical modeling and simulation.
  • Mounting Type4-Bolt
  • Exit Diameter2"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)80 Watts
  • BrandB&C Speakers
  • ModelDE750-8
  • Part Number294-614
  • UPC844632001833
  • Product CategoryHorn Drivers
  • Weight14.18 lbs.
View similar products to the B&C DE750-8 2" Titanium Horn Driver 8 Ohm 4-Bolt
in the Horn Drivers product category.
