B&C DE250-8 1" Polyimide Horn Driver 8 Ohm 2/3-Bolt
Brand:|Model: DE250-8|Part # 294-605
The B&C Speakers DE250 1" HF driver uses its polyimide diaphragm and optimized ferrite motor to great effect. It is a durable, accurate, and great-sounding professional audio transducer.
- Order Soon - Only 3 Left In StockMore Due In December 13, 2016
List Price$172.18
You Save40%
Part # 294-605
  • Polyimide diahpragm for smooth and natural response
  • Recommended crossover of 1,600 Hz or higher with 12 dB slope
  • Considered one of the best sounding 1" compression drivers available
  • Extremely high efficiency is perfect for high output systems
  • 1" bolt-on format (2-bolt/3-bolt)
B&C's DE250 1" high frequency compression driver features smooth and accurate response. Its low mass polyimide diaphragm and optimized ceramic magnet assembly allow high sensitivity and low distortion up to 18 kHz. Popular with professional users as well as many discriminating "high efficiency" home audio enthusiasts, the B&C Speakers DE250 is considered one of the most listenable high performance 1" HF drivers available.
Specifications: • Power handling: 60 watts RMS/120 watts program above recommended crossover of 1.6 kHz/12 dB slope • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 1,000-18,000 Hz • SPL: 108.5 dB 1W/1m • Dimensions: 4.7" diameter x 2.4" depth • Net weight: 4.6 lb. • Replacement diaphragm available.
  • Mounting Type2-Bolt/3-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialPoly / Mylar
  • Impedance8 ohms
  • Power Handling (RMS)60 Watts
  • BrandB&C Speakers
  • ModelDE250-8
  • Part Number294-605
  • UPC844632001765
  • Product CategoryHorn Drivers
    (11 Reviews)
  • Weight5 lbs.
View similar products to the B&C DE250-8 1" Polyimide Horn Driver 8 Ohm 2/3-Bolt
in the Horn Drivers product category.
