B&C 8NDL51-16 8" Professional Neodymium Woofer 16 Ohm
Brand:|Model: 8NDL51-16|Part # 294-5914
B&C's 8NDL51-16 8" speaker offers the efficiency and smooth response of a midrange driver and combines it with the Xmax capabilities of a woofer, making it perfect for a variety of compact pro PA loudspeaker applications.
Ships in 7-10 Business Days
List Price$194.41
You Save40%
Part # 294-5914
  • Great for line arrays and horn loading
  • Neodymium magnet assembly
  • Ventilated voice coil gap for reduced power compression
  • Inductance-reducing copper cap on pole piece extends HF response
  • 2" copper voice coil on polyimide former
  • 400 watts continuous program power capacity
  • 65 – 3,000 Hz response
Frequently Bought Together
The B&C Speakers 8NDL51-16 is an efficient and lightweight cast frame 8" neodymium driver. Its ventilated voice coil gap ensures long term power handling and reduced power compression, and a copper cap on the pole piece reduces inductance and extends high frequency response. The 8NDL51-16 is highly recommended for compact 2-way speaker systems or as the midbass/midrange element in high-output 3-way and 4-way designs.
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance16 ohms
  • Frequency Response65 to 3,000 Hz
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)66 Hz
  • DC Resistance (Re)5.3 ohms
  • Voice Coil Inductance (Le)0.5 mH
  • Mechanical Q (Qms)3.6
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.5 ft.³
  • BL Product (BL)12.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)28g
  • Maximum Linear Excursion (Xmax)7 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.8"
  • Baffle Cutout Diameter7.4"
  • Depth3.5"
  • Bolt Circle Diameter8.3"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model8NDL51-16
  • Part Number294-5914
  • UPC848864009476
  • Weight4.8 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the B&C 8NDL51-16 8" Professional Neodymium Woofer 16 Ohm
