294-5913_ALT_0
B&C 8MDN51-16 8" Professional Neodymium Woofer 16 Ohm
Brand:|Model: 8MDN51-16|Part # 294-5913
Highly recommended for compact 2-way speaker systems, the B&C Speakers 8MDN51-16 8" driver also performs well as the midbass/midrange element in high-output 3-way and 4-way designs, including line arrays.
ORDER TODAY
Ships in 7-10 Business Days
List Price$245.78
You Save40%
$147.47
Part # 294-5913
  • Great for line arrays and horn loading
  • Neodymium ring magnet assembly
  • Ventilated voice coil gap for reduced power compression
  • 2" aluminum voice coil on polyimide former
  • 400 watts continuous program power capacity
  • 70 – 4,000 Hz response
B&C's 8MDN51-16 8" woofer is an efficient and lightweight cast frame neodymium professional driver. Its ventilated voice coil gap ensures long term power handling and reduced power compression. Although the 8MDN51-16 will provide great results when loaded into direct radiating designs, it is also ideally suited for horn-loaded speaker systems.
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance16 ohms
  • Frequency Response70 to 4,000 Hz
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)70 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.8 mH
  • Mechanical Q (Qms)3.7
  • Electromagnetic Q (Qes)0.21
  • Total Q (Qts)0.2
  • Compliance Equivalent Volume (Vas)0.6 ft.³
  • BL Product (BL)15.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)23g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.8"
  • Baffle Cutout Diameter7.4"
  • Depth3.74"
  • Bolt Circle Diameter8.3"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model8MDN51-16
  • Part Number294-5913
  • UPC848864009469
    (1 Reviews)
  • Weight7 lbs.
View similar products to the B&C 8MDN51-16 8" Professional Neodymium Woofer 16 Ohm
