294-5766_ALT_0
294-5766_ALT_1
B&C 8FCX51 8" Professional Coaxial Speaker 100 x 100 8 Ohm
Brand:|Model: 8FCX51|Part # 294-5766
The B&C 8FCX51 8" coaxial transducer is the speaker of choice for high-output professional audio applications, and offers resolution and accuracy worthy of studio monitor or high-efficiency home audio systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$387.41
You Save40%
$232.45
Part # 294-5766
  • Coaxial HF driver with 1.7" voice coil, polyimide diaphragm, and 100° nominal coverage
  • High-energy ferrite magnet shared by LF and HF components
  • Woofer's aluminum-wound 2" voice coil ensures good power handling
  • 1.8 kHz recommended crossover point
  • Use with passive or active crossover (not included)
B&C's 8FCX51 8" coaxial speaker achieves very high levels of accurate audio reproduction. Point source loudspeakers offer improvements in overall coherency, thanks to optimized driver alignment. The 8FCX51's ceramic motor, polyimide diaphragm HF driver, and FEA-optimized design produce truly professional results.
  • Nominal Diameter8"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance8 ohms
  • Frequency Response69 to 18,000 Hz
  • Sensitivity96 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)69 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.9 mH
  • Mechanical Q (Qms)6.3
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.56 ft.³
  • BL Product (BL)11.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)22g
  • Maximum Linear Excursion (Xmax)6.5 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialCoated Paper
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.8"
  • Baffle Cutout Diameter7.4"
  • Depth4.64"
  • Bolt Circle Diameter8.3"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model8FCX51
  • Part Number294-5766
  • UPC848864008837
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight13 lbs.
View similar products to the B&C 8FCX51 8" Professional Coaxial Speaker 100 x 100 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
