294-5765_ALT_0
B&C 8CXN51-16 8" Professional Neodymium Coaxial Speaker 100 x 100 16 Ohm
Brand:|Model: 8CXN51-16|Part # 294-5765
The B&C 8CXN51-16 speaker's neodymium LF/HF motor, polyimide diaphragm HF driver, and FEA-optimized design produce high output and minimal distortion.
ORDER TODAY
Ships in 7-10 Business Days
List Price$429.05
You Save40%
$257.43
Part # 294-5765
  • Coaxial HF driver with 1.7" voice coil, polyimide diaphragm, and 100° nominal coverage
  • Neodymium ring magnet shared by LF and HF components keeps weight low
  • Aluminum-wound 2" woofer voice coil ensures good power handling
  • 1.8 kHz recommended crossover point
  • Use with passive or active crossover (not included)
B&C's 8CXN51-16 8" coaxial loudspeaker produces generous amount of low-distortion output despite its compact form factor. This 16 ohm version of the 8CXN51-8 offers resolution and accuracy that are suitable for professional "fill" loudspeakers, stage monitor wedges, studio monitors, or high-efficiency home audio systems. Power handling is 500 watts continuous program, which combined with the driver's high efficiency results in very good maximum output.
The B&C 8CXN51-16 8" coaxial speaker's optimized driver alignment delivers the coherency and focus expected from a point source design. In addition to this superior articulation and accuracy, the 8CN51-16 requires very little baffle area compared to separate LF and HF components.
  • Nominal Diameter8"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance16 ohms
  • Sensitivity96 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)68 Hz
  • DC Resistance (Re)8.0 ohms
  • Voice Coil Inductance (Le)1.07 mH
  • Mechanical Q (Qms)4.22
  • Electromagnetic Q (Qes)0.34
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)0.65 ft.³
  • Mechanical Compliance of Suspension (Cms)27.06 mm/N
  • BL Product (BL)14.14 Tm
  • Diaphragm Mass Inc. Airload (Mms)20g
  • Maximum Linear Excursion (Xmax)6.0 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.8"
  • Baffle Cutout Diameter7.4"
  • Depth4.4"
  • Bolt Circle Diameter8.27"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model8CXN51-16
  • Part Number294-5765
  • UPC848864008820
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight7 lbs.
View similar products to the B&C 8CXN51-16 8" Professional Neodymium Coaxial Speaker 100 x 100 16 Ohm
in the Pro Coaxial Full-Range Speakers product category.
