B&C 8CX21 8" Professional Coaxial Speaker 100 x 100 8 Ohm
Brand:|Model: 8CX21|Part # 294-5763
The B&C 8CX21 8" coaxial speaker's optimized driver alignment delivers the coherency and focus expected from a point source design.
List Price$290.20
You Save40%
$174.12
Part # 294-5763
  • Coaxial HF driver with 1.4" voice coil, polyester diaphragm, and 100° nominal coverage
  • High-energy ferrite magnets on LF and HF components
  • Copper-wound 2" woofer voice coil ensures good power handling
  • 2.2 kHz recommended crossover point
  • Use with passive or active crossover (not included)
Frequently Bought Together
B&C's 8CX21 8" coaxial loudspeaker produces generous amount of low-distortion output despite its compact form factor. The 8CX21 offers resolution and accuracy that are suitable for professional "fill" loudspeakers, stage monitor wedges, studio monitors, or high-efficiency home audio systems. Power handling is 400 watts continuous program, which combined with the driver's high efficiency results in very good maximum output.
The 8CX21's ceramic ferrite LF/HF motor, polyester diaphragm HF driver, and FEA-optimized design produce high output and minimal distortion. In addition to the superior articulation and accuracy of coaxially aligned drivers, the 8CX21 requires very little baffle area compared to separate LF and HF components.
Specifications (Woofer): • Power Handling: 200 watts RMS/ 400 watts continuous program • VC dia: 2" • Le: 1.2 mH • Impedance: 8 ohms • Re: 5.2 ohms • Frequency response: 80 – 4,000 Hz • Fs: 74 Hz • SPL: 94 dB 2.83V/1m • Vas: 0.55 cu. ft. • Qms: 4.1 • Qes: 0.39 • Qts: 0.36 • Xmax: 5 mm
Specifications (Compression driver): • Power handling: 25 watts RMS/ 50 watts continuous program (with recommended crossover of 2,200 Hz/12 dB slope) • VCdia: 1.4" • Impedance: 8 ohms • Frequency response: 2,000 – 20,000 Hz • SPL: 101 dB 2.83v/1m
Dimensions: • Outside diameter: 8.8" • Cutout diameter: 7.4" • Depth: 5.3"
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response75 to 20,000 Hz
  • Sensitivity94 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)74 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)4.1
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)0.55 ft.³
  • BL Product (BL)11.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)21g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)220 cm²
  • Cone MaterialCoated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.8"
  • Baffle Cutout Diameter7.4"
  • Depth5.3"
  • Bolt Circle Diameter8.3"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model8CX21
  • Part Number294-5763
  • UPC848864008806
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight10.5 lbs.
View similar products to the B&C 8CX21 8" Professional Coaxial Speaker 100 x 100 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
