B&C 6PEV13 6-1/2" Midrange Speaker
Brand:|Model: 6PEV13|Part # 294-650
The B&C Speakers 6PEV13 high efficiency 6.5" cone midrange is ideally suited for three and four way systems.
List Price$148.58
You Save40%
$89.15
Part # 294-650
  • High efficiency allows use with powerful woofers and HF components
  • Aluminum phase plug maintains high axial sensitivity
  • Aluminum voice coil on fiberglass former
  • Smooth, detailed response
  • Die cast frame for durability and proper alignment
  • Lightweight yet well-damped paper cone with flat foam edge
B&C's 6PEV13 6-1/2" midrange speaker features great sensitivity and very smooth response from 400 Hz to 8 kHz. An aluminum phase plug increases the 6PEV13's axial sensitivity and controls its high frequency dispersion. Aluminum voice coil on fiberglass former.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)120 Watts
  • Power Handling (max)240 Watts
  • Impedance8 ohms
  • Frequency Response150 to 8,000 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)126 Hz
  • DC Resistance (Re)5.2 ohms
  • Voice Coil Inductance (Le)0.6 mH
  • Mechanical Q (Qms)4.6
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)0.21 ft.³
  • BL Product (BL)8.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)6g
  • Maximum Linear Excursion (Xmax)0.6 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.7"
  • Depth3.1"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes4
  • Sealed Volume0.04 ft.³
  • Sealed F3299 Hz
  • Vented Volume0.11 ft.³
  • Vented F3174 Hz
  • BrandB&C Speakers
  • Model6PEV13
  • Part Number294-650
  • UPC844632002014
    (8 Reviews)
  • Weight5.3 lbs.
