B&C 6NDL44 6-1/2" Professional Neodymium Woofer 8 Ohm
Brand:|Model: 6NDL44|Part # 294-647
The B&C Speakers 6NDL44 6-1/2" neo woofer offers exceptional power handling capacity combined with smooth, linear frequency response.
List Price$198.55
You Save40%
$119.13
Part # 294-647
  • Woofer/midrange
  • High-energy neodymium motor
  • 400 watt continuous program power
  • 1.7" copper voice coil on a polyimide former
  • Smooth, extended frequency response
  • 91.5 dB 1w/1m sensitivity
B&C's 6NDL44 6-1/2" cast frame neodymium woofer is a lightweight, powerful choice for ultra-compact multi-way speaker systems. Its rubber half-roll edge and treated cone are engineered to handle high bass excursions without drama, while still allowing a clean, articulate sonic signature. The 6NDL44 is also suitable as the midrange element in medium efficiency 3-way applications.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response70 to 6,000 Hz
  • Sensitivity91.5 dB 1W/1m
  • Voice Coil Diameter1.7"
  • Resonant Frequency (Fs)68 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)9
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.26 ft.³
  • BL Product (BL)10.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)17.8g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.7"
  • Depth3.2"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes8
  • Sealed Volume0.05 ft.³
  • Sealed F3171 Hz
  • Vented Volume0.12 ft.³
  • Vented F3103 Hz
  • BrandB&C Speakers
  • Model6NDL44
  • Part Number294-647
  • UPC844632086038
    (1 Reviews)
  • Weight2.7 lbs.
View similar products to the B&C 6NDL44 6-1/2" Professional Neodymium Woofer 8 Ohm
