294-647_ALT_0
294-647_ALT_1
294-647_ALT_2
B&C 6NDL44 6-1/2" Neodymium Woofer
Brand:| Model: 6NDL44
The B&C Speakers 6NDL44 6-1/2" neo woofer offers exceptional power handling capacity combined with smooth, linear frequency response.
  • Woofer/midrange
  • High-energy neodymium motor
  • 400 watt continuous program power
  • 1.7" copper voice coil on a polyimide former
  • Smooth, extended frequency response
  • 91.5 dB 1w/1m sensitivity
294-647
Weight: 2.7 lbs.
IN STOCK
List Price$215.39
You Save43%
$121.23
Part # 294-647
B&C's 6NDL44 6-1/2" cast frame neodymium woofer is a lightweight, powerful choice for ultra-compact multi-way speaker systems. Its rubber half-roll edge and treated cone are engineered to handle high bass excursions without drama, while still allowing a clean, articulate sonic signature. The 6NDL44 is also suitable as the midrange element in medium efficiency 3-way applications.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response70 to 6,000 Hz
  • Sensitivity91.5 dB 1W/1m
  • Voice Coil Diameter1.7"
  • Resonant Frequency (Fs)68 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)9
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.26 ft.³
  • BL Product (BL)10.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)17.8g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.7"
  • Depth3.2"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes8
Optimum Cabinet Size *
  • Sealed Volume0.05 ft.³
  • Sealed F3171 Hz
  • Vented Volume0.12 ft.³
  • Vented F3103 Hz
  • * Enclosure volume/F3s based on BassBox "optimum" calculations-
  • BrandB&C Speakers
  • Model6NDL44
  • Part Number294-647
  • UPC844632086038
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (1 Reviews)
  • Weight2.7 lbs.
View similar products to the B&C 6NDL44 6-1/2" Neodymium Woofer
in the Woofers, Subwoofers & Midrange Speakers product category.
B&C 6NDL44 6-1/2" Neodymium Woofer is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from look this baby over and you see real build qualityI've building speakers for over 35 years ,this driver I thought a little expensive but the results that i got from my latest design were right on the money ,they're worth every penny.
Date published: 0001-04-10
Good for Car Audio?
I think the sensitivity makes up for that fact that it's 8ohms but how will it perform in the airspace of a car door?
Asked by: Beatnik
It would work for sure, with a Vas of .26 the door will be pretty close to an infinite baffle for it though. That means excellent transients, but poor power handling. You may want to put in a passive high pass filter tuned to about 70hz if you have a subwoofer to fill in the bottom end. The Neo magnet drives the price up as well.If you plan on powering it with your deck, it is a bit of overkill. The vast majority of mobile audio decks are about 50W per channel, OE ones usually even less. This driver is capable of 400W!In an all-out bassmobile, with a good amp, this speaker will keep up no problems. If that's what you need then this is the one. Put it in a tiny little box to keep the cone under control and use a 200Wrms amp to drive it.
Answered by: doublejay
Date published: 2012-08-14
Customer projects that include: B&C 6NDL44 6-1/2" Neodymium Woofer
