294-5904_ALT_0
B&C 6NDL38-16 6.5" Professional Neodymium Woofer 16 Ohm
Brand:|Model: 6NDL38-16|Part # 294-5904
B&C developed the 6NDL38-16 6.5" cast frame neodymium woofer/midrange for high output compact speaker systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$188.84
You Save40%
$113.30
Part # 294-5904
  • Designed for woofer and midrange applications
  • High-energy neodymium motor
  • 300 watt continuous program power
  • 1.5" copper voice coil on a polyimide former
  • 6 mm Xmax
Frequently Bought Together
B&C developed the 6NDL38-16 6.5" cast frame neodymium woofer/midrange for high output compact speaker systems. The rubber half-roll cone surround and long copper voice coil provide high excursion capability, and an aluminum demodulation ring reduces distortion.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance16 ohms
  • Frequency Response70 to 6,000 Hz
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)72 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.6 mH
  • Mechanical Q (Qms)11.5
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.42
  • Compliance Equivalent Volume (Vas)0.25 ft.³
  • BL Product (BL)9.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)17g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.7"
  • Depth3.3"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes4
  • Sealed Volume0.09 ft.³
  • Sealed F3135 Hz
  • Vented Volume0.24 ft.³
  • Vented F371 Hz
  • BrandB&C Speakers
  • Model6NDL38-16
  • Part Number294-5904
  • UPC848864009384
  • Weight2.6 lbs.
RCF L15/554K 15" Woofer Speaker
Part #  294-866
RCF L15S801 15" Woofer Speaker
Part #  294-864
View similar products to the B&C 6NDL38-16 6.5" Professional Neodymium Woofer 16 Ohm
