294-5903_ALT_0
B&C 6MDN44-16 6.5" Professional Neodymium Midrange Speaker 16 Ohm
Brand:|Model: 6MDN44-16|Part # 294-5903
The B&C Speakers 6MDN44 6-1/2" neodymium midrange driver is a great choice for high output, multi-way loudspeaker systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$169.40
You Save40%
$101.64
Part # 294-5903
  • Designed for midrange applications
  • High-energy neodymium motor
  • 300 watt continuous program power
  • 1.7" aluminum voice coil on a fiberglass former
  • Aluminum demodulation ring lowers distortion
Frequently Bought Together
B&C's 6MDN44-16 6.5" speaker was designed for professional midrange applications that require high output and low distortion. The 6MDN44-16's powerful neodymium magnet reduces driver weight while maintaining superb efficiency, complemented by a short, low-mass aluminum voice coil. An aluminum demodulation ring in the motor circuit reduces distortion.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance16 ohms
  • Frequency Response150 to 6,000 Hz
  • Voice Coil Diameter1.7"
  • Resonant Frequency (Fs)140 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.47 mH
  • Mechanical Q (Qms)2.8
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.09 ft.³
  • BL Product (BL)11 Tm
  • Diaphragm Mass Inc. Airload (Mms)11g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.7"
  • Depth2.9"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3299 Hz
  • Vented Volume0.07 ft.³
  • Vented F3165 Hz
  • BrandB&C Speakers
  • Model6MDN44-16
  • Part Number294-5903
  • UPC848864009377
  • Weight2.2 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the B&C 6MDN44-16 6.5" Professional Neodymium Midrange Speaker 16 Ohm
