294-5902_ALT_0
B&C 6MD38-16 6.5" Professional Midrange Speaker 16 Ohm
Brand:|Model: 6MD38-16|Part # 294-5902
A dedicated pro midrange with a pincushion-style cast frame, B&C's 6MD38-16 6.5" speaker is loud, clean, and reliable.
- Order Soon - Only 1 Left In StockMore Due In November 15, 2016
List Price$149.96
You Save40%
$89.98
Part # 294-5902
  • 16 ohm nominal impedance, perfect for dual driver 8 ohm compact speaker systems
  • Durable cast aluminum frame
  • 1.5" aluminum voice coil on fiberglass former
  • Smooth, wide frequency response
  • Great performance in direct radiator and horn loaded designs
The B&C Speakers 6MD38-16 is a high efficiency 6.5" cone midrange that is engineered to provide excellent results when installed in three and four way systems. The 6MD38-16 features very smooth response from 1.5 to 6 kHz. An aluminum voice coil on a fiberglass former promotes efficiency combined with durability.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)120 Watts
  • Power Handling (max)240 Watts
  • Impedance16 ohms
  • Frequency Response150 to 6,000 Hz
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)130 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.25 mH
  • Mechanical Q (Qms)3.7
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)0.1 ft.³
  • BL Product (BL)10.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)12g
  • Maximum Linear Excursion (Xmax)2 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.7"
  • Depth3.2"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes4
  • Sealed Volume0.03 ft.³
  • Sealed F3253 Hz
  • Vented Volume0.11 ft.³
  • Vented F3133 Hz
  • BrandB&C Speakers
  • Model6MD38-16
  • Part Number294-5902
  • UPC848864009360
  • Weight5.25 lbs.
View similar products to the B&C 6MD38-16 6.5" Professional Midrange Speaker 16 Ohm
