294-5762_ALT_0
B&C 6HCX51 6.5" Professional Neodymium Coaxial Speaker 70 x 70 8 Ohm
Brand:|Model: 6HCX51|Part # 294-5762
The B&C 6HCX51 6.5" neodymium coaxial speaker's point source design offers improvements in overall coherency, thanks to optimized driver alignment.
ORDER TODAY
Ships in 7-10 Business Days
List Price$349.90
You Save40%
$209.94
Part # 294-5762
  • Coaxial HF driver with 1.4" voice coil, polyester diaphragm, and 70° X 70° coverage
  • Neodymium ring magnet shared by LF and HF components keeps weight below 3-1/2 lbs.
  • Copper-wound 2" woofer voice coil ensures good power handling
  • 2.2 kHz recommended crossover point
  • Use with passive or active crossover (not included)
 B&C's 6HCX51 6.5" coaxial loudspeaker produces generous amount of low-distortion output despite its compact form factor. The class-leading 6HCX51 offers resolution and accuracy that are suitable for professional "fill" loudspeakers, studio monitors, or high-efficiency home audio systems.
The 6HCX51's neodymium LF/HF motor, polyester diaphragm HF driver, and FEA-optimized design produce high output and minimal distortion. In addition to the superior articulation and accuracy of coaxially aligned drivers, the 6HCX51 requires very little baffle area compared to separate LF and HF components.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance8 ohms
  • Frequency Response90 to 18,000 Hz
  • Sensitivity92 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)89 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.8 mH
  • Mechanical Q (Qms)7.5
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.18 ft.³
  • BL Product (BL)10.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)16g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialCoated Paper
  • Magnet MaterialNeodymium
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.75"
  • Depth4.1"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes4
  • BrandB&C Speakers
  • Model6HCX51
  • Part Number294-5762
  • UPC848864008790
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight3.5 lbs.
View similar products to the B&C 6HCX51 6.5" Professional Neodymium Coaxial Speaker 70 x 70 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
