CLEARANCE
294-5761_ALT_0
294-5761_ALT_1
B&C 6FHX51 6.5" Professional Coaxial Speaker 70 x 70 8 Ohm
Brand:|Model: 6FHX51|Part # 294-5761
The B&C 6FHX51 6.5" coaxial speaker delivers big sound, despite its compact size. It offers resolution and accuracy that are appropriate for studio monitor or high-efficiency home audio systems.
List Price$240.19
You Save40%
$144.15
Part # 294-5761
  • Coaxial HF driver with polyester diaphragm and 70° X 70° coverage
  • Neodymium HF motor combined with ferrite magnet woofer
  • Copper-wound 2" woofer voice coil ensures good power handling
  • Use with passive or active crossover (not included)
B&C's 6FHX51 6.5" coaxial speaker offers pro-quality performance and a compact footprint. Point source loudspeakers offer improvements in overall coherency thanks to optimized driver alignment.
The 6FHX51's ceramic motor (woofer), polyester diaphragm neodymium HF driver, and FEA-optimized design produce high output and low distortion. In addition to the superior articulation and accuracy of coaxially aligned drivers, the 6FHX51 requires very little baffle area compared to separate LF and HF components.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance8 ohms
  • Frequency Response85 to 18,000 Hz
  • Sensitivity93 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)85 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)1 mH
  • Mechanical Q (Qms)7.8
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.18 ft.³
  • BL Product (BL)11.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)16g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)132 cm²
  • Cone MaterialCoated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.4"
  • Baffle Cutout Diameter5.75"
  • Depth4.8"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes4
  • BrandB&C Speakers
  • Model6FHX51
  • Part Number294-5761
  • UPC848864008783
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight7.25 lbs.
View similar products to the B&C 6FHX51 6.5" Professional Coaxial Speaker 70 x 70 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
