294-5760_ALT_0
294-5760_ALT_1
B&C 5FCX44 5" Professional Coaxial Speaker 70 x 70 8 Ohm
Brand:|Model: 5FCX44|Part # 294-5760
B&C's 5FCX44 5" coaxial speaker is designed for high-output professional audio applications. It offers resolution and accuracy that are appropriate for studio monitor or high-efficiency home audio systems.
List Price$224.91
You Save40%
$134.95
Part # 294-5760
  • Coaxial HF driver with polyester diaphragm and 70° X 70° coverage
  • Neodymium HF motor combined with ferrite magnet woofer
  • Copper-wound 1.7" woofer voice coil
  • Use with passive or active crossover (not included)
The B&C 5FCX44 coaxial speaker achieves very high levels of accurate audio reproduction. Point source loudspeakers offer improvements in overall coherency thanks to optimized driver alignment. The 5FCX44's ceramic motor (woofer), polyester diaphragm neodymium HF driver, and FEA-optimized design produce a truly professional performance.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance8 ohms
  • Frequency Response60 to 18,000 Hz
  • Sensitivity91 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)61 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)0.8 mH
  • Mechanical Q (Qms)7.8
  • Electromagnetic Q (Qes)0.25
  • Total Q (Qts)0.25
  • Compliance Equivalent Volume (Vas)0.25 ft.³
  • BL Product (BL)10.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)12g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)95 cm²
  • Cone MaterialCoated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.35"
  • Baffle Cutout Diameter4.8"
  • Depth4.33"
  • Bolt Circle Diameter5.6"
  • # Mounting Holes4
  • BrandB&C Speakers
  • Model5FCX44
  • Part Number294-5760
  • UPC848864008776
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight5.1 lbs.
View similar products to the B&C 5FCX44 5" Professional Coaxial Speaker 70 x 70 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
