B&C 18SW115 18" Neodymium Subwoofer Speaker Driver
Brand:|Model: 18SW115|Part # 294-575
B&C's 18SW115 18" pro subwoofer speaker boasts an oversized 4.5" voice coil, neodymium motor, 1,700 watts RMS power handling capacity, and 14 mm Xmax (60 mm peak-to-peak excursion before damage).
- Order Soon - Only 3 Left In Stock
List Price$790.04
You Save40%
$474.03
Part # 294-575
  • Lightweight but powerful FEA-optimized neodymium magnet
  • Extremely high BL factor and Xmax for outstanding LF output
  • 14 mm Xmax, 60 mm peak-to-peak excursion before damage
  • 4.5" split winding copper voice coil on fiberglass former
  • Ventilated voice coil gap reduces power compression
  • Aluminum demodulation ring on pole piece reduces distortion
  • Double silicone spider
The B&C 18SW115 is an advanced, lightweight subwoofer driver featuring 1,700 watts RMS power handling, a 1.33" long/4.5" diameter copper voice coil with very high thermal capability, and a ventilated neodymium magnet assembly that provides low power compression. An aluminum demodulation ring fitted to the 18SW115's pole piece reduces distortion.
  • Nominal Diameter18"
  • Power Handling (RMS)1,700 Watts
  • Power Handling (max)3400 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,500 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter4.5"
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)5.3 ohms
  • Voice Coil Inductance (Le)1.9 mH
  • Mechanical Q (Qms)5.6
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.3
  • Compliance Equivalent Volume (Vas)6.5 ft.³
  • BL Product (BL)30.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)275g
  • Maximum Linear Excursion (Xmax)14 mm
  • Surface Area of Cone (Sd)1210 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter18"
  • Baffle Cutout Diameter16.6"
  • Depth9.5"
  • Bolt Circle Diameter17.44"
  • # Mounting Holes8
  • Sealed Volume1.04 ft.³
  • Sealed F384 Hz
  • Vented Volume2.08 ft.³
  • Vented F353 Hz
  • BrandB&C Speakers
  • Model18SW115
  • Part Number294-575
  • UPC844632086120
  • Weight30.4 lbs.
