B&C 15NA100 15" Neodymium Woofer Speaker Driver
Brand:|Model: 15NA100|Part # 294-573
The B&C 15NA100 15" speaker features a well-ventilated and powerful neodymium magnet system that helps propel the driver to superb performance in professional PA loudspeaker systems.
List Price$554.01
You Save40%
Part # 294-573
  • Lightweight but powerful FEA-optimized neodymium magnet
  • Ventilated voice coil gap reduces power compression
  • Double silicone spider
  • High efficiency and BL factor
  • 1,600 watt continuous program power
  • 4" aluminum voice coil on fiberglass former
  • 98 dB 1W/1m sensitivity
The B&C Speakers 15NA100 15" speaker is an advanced, lightweight subwoofer driver featuring 800 watts RMS power handling, a 4" diameter aluminum voice coil, and a ventilated neodymium magnet assembly that ensures low power compression.
  • Nominal Diameter15"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance8 ohms
  • Frequency Response45 to 2,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)47 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)6.1
  • Electromagnetic Q (Qes)0.29
  • Total Q (Qts)0.28
  • Compliance Equivalent Volume (Vas)3.1 ft.³
  • BL Product (BL)26.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)136g
  • Maximum Linear Excursion (Xmax)10 mm
  • Surface Area of Cone (Sd)855 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.9"
  • Depth7.09"
  • Bolt Circle Diameter14.7"
  • # Mounting Holes8
  • Sealed Volume0.4 ft.³
  • Sealed F3135 Hz
  • Vented Volume0.8 ft.³
  • Vented F386 Hz
  • BrandB&C Speakers
  • Model15NA100
  • Part Number294-573
  • UPC844632086106
  • Weight22.0000 lbs.
B&C 6PS38 6.5" Professional Woofer 8 Ohm
Part #  294-5906
B&C 12NW76 12" Neodymium Woofer
Part #  294-681
Pyle PBW10S 10" Midbass
Part #  292-2528
RCF L15P540 15" Woofer Speaker
Part #  294-860
View similar products to the B&C 15NA100 15" Neodymium Woofer Speaker Driver
