294-5773_ALT_0
294-5773_ALT_1
B&C 15FHX76 15" Professional Coaxial Speaker 60 x 40 8 Ohm
Brand:|Model: 15FHX76|Part # 294-5773
An exponential horn flare increases the B&C 15FHX76 15" coaxial speaker's HF acoustic loading and improves pattern control.
ORDER TODAY
Ships in 7-10 Business Days
List Price$651.19
You Save40%
$390.72
Part # 294-5773
  • 15" woofer combined with coaxial large format HF driver for massive output and wide range
  • Coaxial HF driver with 3" voice coil, titanium diaphragm, and 60° x 40° nominal coverage
  • High-energy ferrite magnet shared by LF and HF components
  • Woofer's copper-wound 3" voice coil ensures good power handling
  • Modified exponential horn flare increases HF acoustic loading and shapes the coverage pattern
  • 1.2 kHz recommended crossover point
  • Use with passive or active crossover (not included)
B&C's 15FHX76 15" coaxial loudspeaker produces generous amount of low-distortion output despite its compact form factor. The 15FHX76 offers resolution and accuracy that are suitable for professional "fill" loudspeakers, stage monitor wedges, studio monitors, or high-efficiency home audio systems. A built-in 60° x 40° horn offers useful pattern control, particularly handy when trying to limit sound energy that is directed at floors and ceilings, for example.
The 15FHX76's large-format HF compression driver permits an exceptionally low crossover point of 1,200 Hz, which offers a more consistent directivity transition from LF cone to HF horn. Power handling is 800 watts continuous program; combined with the driver's high efficiency, this results in very good maximum output.
  • Nominal Diameter15"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response40 to 18,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)40 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.5 mH
  • Mechanical Q (Qms)5.2
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)6.56 ft.³
  • BL Product (BL)15.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)88g
  • Maximum Linear Excursion (Xmax)6.5 mm
  • Surface Area of Cone (Sd)855 cm²
  • Cone MaterialCoated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.94"
  • Depth7.83"
  • Bolt Circle Diameter14.7"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model15FHX76
  • Part Number294-5773
  • UPC848864008851
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight25 lbs.
View similar products to the B&C 15FHX76 15" Professional Coaxial Speaker 60 x 40 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
