B&C 15CXN76 15" Neodymium Coaxial Speaker 80 x 80 Degree
Brand:|Model: 15CXN76|Part # 294-578
The B&C 15CXN76 15" coaxial speaker is efficient in design and output, thanks to its powerful and compact neodymium motor structure that is shared by the transducer's low and high frequency sections.
ORDER TODAY
Ships in 7-10 Business Days
List Price$762.26
You Save40%
$457.36
Part # 294-578
  • Transparent, accurate point source transducer
  • Efficient, low-distortion coaxial design
  • 80° nominal HF coverage
  • Strong, lightweight neodymium integrated magnetic structure
  • Woofer rated at 800 watt continuous program power handling
  • Cloth multi-roll surround, light moving mass, and exponential cone geometry
  • Titanium diaphragm high frequency driver with polyester surround
B&C's 15CXN76 15" coaxial speaker is ideal for use in applications that require very high efficiency and fidelity. A single, integrated neodymium magnetic assembly drives both the low and high frequency driver elements. The 15CXN76's large-format high frequency driver provides wide, even 80° coverage. Especially recommended for compact bass reflex enclosures, stage monitors, and high-SPL ceiling speaker applications. Crossover not included. Recommended 12 dB/octave crossover frequency: 1,200 Hz.
  • Nominal Diameter15"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response40 to 18,000 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)38 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)0.9 mH
  • Mechanical Q (Qms)5.8
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.28
  • Compliance Equivalent Volume (Vas)8.6 ft.³
  • BL Product (BL)17.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)82g
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Surface Area of Cone (Sd)855 cm²
  • Cone MaterialPaper
  • Magnet MaterialNeodymium
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.94"
  • Depth7.8"
  • Bolt Circle Diameter14.7"
  • # Mounting Holes8
  • Sealed Volume1.2 ft.³
  • Sealed F3106 Hz
  • Vented Volume2.38 ft.³
  • Vented F367 Hz
  • BrandB&C Speakers
  • Model15CXN76
  • Part Number294-578
  • UPC844632086175
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight16.2500 lbs.
View similar products to the B&C 15CXN76 15" Neodymium Coaxial Speaker 80 x 80 Degree
in the Pro Coaxial Full-Range Speakers product category.
