294-569_ALT_0
294-569_ALT_1
B&C 12TBX100 12" High Power Woofer 8 Ohm
Brand:|Model: 12TBX100|Part # 294-569
State of the art performance in even the smallest possible enclosure sets apart the B&C Speakers 12TBX100 as a benchmark pro loudspeaker.
List Price$411.00
You Save40%
$246.60
Part # 294-569
  • Cast frame and massive ventilated motor system
  • Dual demodulation rings for reduced distortion and inductance
  • Double silicone spider design maintains linearity
  • 4" diameter inside-outside wound copper voice coil
  • 1000 watts RMS power handling and 9 mm Xmax!
Built for high power bass applications where space is limited, B&C's 12TBX100 is a technologically advanced 12" woofer that features 1000 watts RMS power handling, a 1" long, 4" diameter copper voice coil with high thermal capability, and a ventilated magnet assembly that provides low power compression.
Very low distortion and an extended response (due to low inductance) is obtained using a double silicone spider design with dual aluminum demodulation rings in the magnetic path. A proprietary water-proof cone treatment is applied for safe outdoor use and installation in adverse climatic conditions.
  • Nominal Diameter12"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response45 to 1,500 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)1.6 mH
  • Mechanical Q (Qms)6.9
  • Electromagnetic Q (Qes)0.27
  • Total Q (Qts)0.26
  • Compliance Equivalent Volume (Vas)1.3 ft.³
  • BL Product (BL)25.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)119g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)531 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.5"
  • Baffle Cutout Diameter11.1"
  • Depth5.3"
  • Bolt Circle Diameter11.8"
  • # Mounting Holes8
  • Sealed Volume0.15 ft.³
  • Sealed F3129 Hz
  • Vented Volume0.29 ft.³
  • Vented F383 Hz
  • BrandB&C Speakers
  • Model12TBX100
  • Part Number294-569
  • UPC848864006857
  • Weight28 lbs.
View similar products to the B&C 12TBX100 12" High Power Woofer 8 Ohm
