B&C 12PE32 12" Midbass Speaker
Brand:|Model: 12PE32|Part # 294-660
The B&C Speakers 12PE32 12" midbass delivers excellent results in vented and horn loaded loudspeaker enclosures, and exhibits very good linearity up to 2 kHz.
List Price$272.15
You Save40%
$163.29
Part # 294-660
  • Very high efficiency
  • Great in vented and horn loaded enclosures
  • 2.5" aluminum voice coil
  • Detailed, accurate sound reproduction
B&C's 12PE32 is a very high efficiency 12" driver for professional woofer and midbass speaker applications. The 12PE32's 2.5" aluminum voice coil and a low-mass yet stiff cone help provide clean, detailed, high-impact sound reproduction. This Italian-made 12" pro PA speaker resolves fine details in audio program material and reproduces them accurately at concert-level volume.
  • Nominal Diameter12"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity101 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)51 Hz
  • DC Resistance (Re)5.8 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)7.6
  • Electromagnetic Q (Qes)0.19
  • Total Q (Qts)0.18
  • Compliance Equivalent Volume (Vas)3.56 ft.³
  • BL Product (BL)19.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)37g
  • Maximum Linear Excursion (Xmax)2.8 mm
  • Surface Area of Cone (Sd)522 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.4"
  • Baffle Cutout Diameter11.1"
  • Depth5.3"
  • Bolt Circle Diameter11.6"
  • # Mounting Holes8
  • Sealed Volume0.15 ft.³
  • Sealed F3242 Hz
  • Vented Volume0.31 ft.³
  • Vented F3163 Hz
  • BrandB&C Speakers
  • Model12PE32
  • Part Number294-660
  • UPC844632002083
    (9 Reviews)
  • Weight18.7 lbs.
