B&C 12NW100 12" Neodymium Subwoofer Speaker
Brand:|Model: 12NW100|Part # 294-571
B&C's 12NW100 is a superb 12" subwoofer for direct radiator or horn loaded configurations. Also works well as the woofer in high-output 2-way speaker systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$460.97
You Save40%
$276.58
Part # 294-571
  • Extremely high BL factor and generous Xmax deliver massive bass
  • Lightweight but powerful neodymium magnet
  • Ventilated voice coil gap reduces power compression
  • Double silicone spider
  • 2,000 watt continuous program power
  • 1" long, 4" diameter copper voice coil on fiberglass former
  • 96 dB 1W/1m sensitivity
B&C's 12NW100 is a superb 12" subwoofer for direct radiator or horn loaded configurations. Also works well as the woofer in high-output 2-way speaker systems. Good power handling and Xmax capabilities thanks to a well-ventilated neodymium motor, 1" long voice coil, and carefully optimized suspension.
  • Nominal Diameter12"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response45 to 1,500 Hz
  • Sensitivity96 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.9 mH
  • Mechanical Q (Qms)3.6
  • Electromagnetic Q (Qes)0.21
  • Total Q (Qts)0.2
  • Compliance Equivalent Volume (Vas)1.5 ft.³
  • BL Product (BL)28 Tm
  • Diaphragm Mass Inc. Airload (Mms)119g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)531 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.5"
  • Baffle Cutout Diameter11.1"
  • Depth5.4"
  • Bolt Circle Diameter11.8"
  • # Mounting Holes8
  • Sealed Volume0.09 ft.³
  • Sealed F3169 Hz
  • Vented Volume0.17 ft.³
  • Vented F3113 Hz
  • BrandB&C Speakers
  • Model12NW100
  • Part Number294-571
  • UPC844632086083
  • Weight20.05 lbs.
View similar products to the B&C 12NW100 12" Neodymium Subwoofer Speaker
