B&C 12FCX76 12" Professional Coaxial Speaker 80 x 80 8 Ohm
Brand:|Model: 12FCX76|Part # 294-5770
The B&C 12FCX76 12" coaxial speaker's high-strength LF/HF motor, titanium diaphragm HF driver, and FEA-optimized design produce high output and minimal distortion.
Ships in 7-10 Business Days
List Price$553.99
You Save40%
Part # 294-5770
  • Coaxial HF driver with 3" voice coil, titanium diaphragm, and 80° nominal coverage
  • High-energy ferrite magnet shared by LF and HF components
  • Woofer's copper-wound 3" voice coil ensures good power handling
  • 1.2 kHz recommended crossover point
  • Use with passive or active crossover (not included)
B&C's 12FCX76 12" coaxial loudspeaker produces generous amount of low-distortion output despite its compact form factor. The 12FCX76 offers resolution and accuracy that are suitable for professional "fill" loudspeakers, stage monitor wedges, studio monitors, or high-efficiency home audio systems. Power handling is 700 watts continuous program; combined with the driver's high efficiency, this results in very good maximum output. The 12FCX76's large-format HF compression driver permits an exceptionally low crossover point of 1,200 Hz, which offers a more consistent directivity transition from LF cone to HF horn.
  • Nominal Diameter12"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response47 to 18,000 Hz
  • Sensitivity98 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)47 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.3 mH
  • Mechanical Q (Qms)11
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)2.98 ft.³
  • BL Product (BL)15.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)54g
  • Maximum Linear Excursion (Xmax)6.5 mm
  • Surface Area of Cone (Sd)522 cm²
  • Cone MaterialCoated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.5"
  • Baffle Cutout Diameter11.1"
  • Depth6.65"
  • Bolt Circle Diameter11.7"
  • # Mounting Holes8
  • BrandB&C Speakers
  • Model12FCX76
  • Part Number294-5770
  • UPC848864008752
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight22 lbs.
View similar products to the B&C 12FCX76 12" Professional Coaxial Speaker 80 x 80 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
