B&C 12CXN76 12" Neodymium Coaxial Speaker 80 x 80 Degree
Brand:|Model: 12CXN76|Part # 294-576
A neodymium motor system and extensive FEA analysis contribute to the B&C 12CXN76's extreme efficiency and fidelity, useful for pro applications that require high output from a smaller, point source driver.
ORDER TODAY
Ships in 7-10 Business Days
List Price$720.62
You Save40%
$432.37
Part # 294-576
  • Transparent, accurate point source transducer
  • Efficient, low-distortion coaxial design
  • 80° nominal HF coverage
  • Strong, lightweight neodymium integrated magnetic structure
  • Woofer rated at 700 watt continuous program power handling
  • Cloth multi-roll surround, light moving mass, and exponential cone geometry
  • Titanium diaphragm high frequency driver with polyester surround
B&C's highly efficient 12CXN76 12" coaxial speaker delivers coherent, low distortion output while occupying the smallest possible footprint. A single, integrated neodymium magnetic assembly drives both the low and high frequency driver elements, and the 12CXN76's large-format high frequency driver provides wide, even 80° coverage. The B&C 12CXN76 is suited for compact bass reflex enclosures, stage monitors, and high-output ceiling speaker applications. Crossover not included. Recommended 12 dB/octave crossover frequency: 1,200 Hz.
  • Nominal Diameter12"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response45 to 18,000 Hz
  • Sensitivity99 dB 1W/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)0.8 mH
  • Mechanical Q (Qms)8
  • Electromagnetic Q (Qes)0.2
  • Total Q (Qts)0.19
  • Compliance Equivalent Volume (Vas)4.2 ft.³
  • BL Product (BL)17.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)47g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)522 cm²
  • Cone MaterialPaper
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.4"
  • Baffle Cutout Diameter11.1"
  • Depth6.7"
  • Bolt Circle Diameter11.7"
  • # Mounting Holes8
  • Sealed Volume0.25 ft.³
  • Sealed F3172 Hz
  • Vented Volume0.46 ft.³
  • Vented F3115 Hz
  • BrandB&C Speakers
  • Model12CXN76
  • Part Number294-576
  • UPC844632086151
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight11 lbs.
View similar products to the B&C 12CXN76 12" Neodymium Coaxial Speaker 80 x 80 Degree
in the Pro Coaxial Full-Range Speakers product category.
