B&C 10NCX 10" Neodymium Coaxial Speaker
Brand:|Model: 10NCX|Part # 294-685
The B&C 10NCX is based on a compact, lightweight neodymium magnet structure that is shared by the 10" coaxial speaker's LF and HF components.
Comparable Items In Stock:
Part # 294-685
  • Neodymium magnet is light but powerful
  • Ventilated voice coil gap reduces power compression
  • Use with passive or active crossover (not included)
  • 2.5" aluminum voice coil
  • 70° nominal coverage
  • 400 watt continuous program power
  • 94 dB 1w/1m sensitivity (LF), 106 dB 1w/1m sensitivity (HF)
The B&C 10NCX coaxial achieves very high levels of accurate audio reproduction. Point source loudspeakers offer improvements in overall coherency thanks to optimized driver alignment. The 10NCX's neodymium motor, titanium HF driver, and FEA-optimized design work in conjunction to produce a truly professional speaker product. High efficiency and smooth response in a space-saving design!
  • Nominal Diameter10"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response60 to 18,000 Hz
  • Sensitivity94 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)57 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)3.7
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)1.4 ft.³
  • BL Product (BL)12.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)28g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)320 cm²
  • Cone MaterialPaper
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.31"
  • Baffle Cutout Diameter8.8"
  • Depth5.7"
  • # Mounting Holes4
  • Sealed Volume0.21 ft.³
  • Sealed F3152 Hz
  • Vented Volume0.51 ft.³
  • Vented F394 Hz
  • BrandB&C Speakers
  • Model10NCX
  • Part Number294-685
  • UPC844632002304
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight10.1 lbs.
View similar products to the B&C 10NCX 10" Neodymium Coaxial Speaker
in the Pro Coaxial Full-Range Speakers product category.
