294-5767_ALT_0
294-5767_ALT_1
B&C 10FCX64 10" Professional Coaxial Speaker 70 x 70 8 Ohm
Brand:|Model: 10FCX64|Part # 294-5767
The B&C 10FCX64 10" coaxial speaker's high-strength LF/HF motor, titanium diaphragm HF driver, and FEA-optimized design produce high output and minimal distortion.
List Price$492.93
You Save40%
$295.76
Part # 294-5767
  • Coaxial HF driver with 2.5" voice coil, titanium diaphragm, and 70° X 70° coverage
  • High-energy ferrite magnet shared by LF and HF components
  • Woofer's copper-wound 2.5" voice coil ensures good power handling
  • 1.2 kHz recommended crossover point
  • Use with passive or active crossover (not included)
B&C's 10FCX64 10" coaxial loudspeaker produces generous amount of low-distortion output despite its compact form factor. The 10FCX64 offers resolution and accuracy that are suitable for professional "fill" loudspeakers, stage monitor wedges, studio monitors, or high-efficiency home audio systems. Power handling is 500 watts continuous program; combined with the driver's high efficiency, this results in very good maximum output. The 10FCX64's large-format HF compression driver permits an exceptionally low crossover point of 1,200 Hz, which offers a more consistent directivity transition from LF cone to HF horn.
  • Nominal Diameter10"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance8 ohms
  • Frequency Response65 to 18,000 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)63 Hz
  • DC Resistance (Re)6 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)7.9
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.42
  • Compliance Equivalent Volume (Vas)0.89 ft.³
  • BL Product (BL)13.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)37g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)320 cm²
  • Cone MaterialCoated Paper
  • Overall Outside Diameter10.3"
  • Baffle Cutout Diameter8.8"
  • Depth5.7"
  • Bolt Circle Diameter9.6"
  • BrandB&C Speakers
  • Model10FCX64
  • Part Number294-5767
  • UPC848864008660
  • Product CategoryPro Coaxial Full-Range Speakers
  • Weight14.5 lbs.
View similar products to the B&C 10FCX64 10" Professional Coaxial Speaker 70 x 70 8 Ohm
in the Pro Coaxial Full-Range Speakers product category.
