BBE DS48 4-Input 8-Output Loudspeaker Management System
Brand:|Part # 246-2326
The DS48 loudspeaker management system is a comprehensive sound reinforcement tool that offers 4 input/8 output connectivity, parametric equalizer, crossovers, limiters and time delays.
  • 4 inputs and 8 outputs with 10 configuration templates
  • High performance limiters on each output
  • Release and threshold parameters
  • Independent control of each high and low pass filter
  • XLR input/output connectors
  • Selectable line voltages between 90 and 250 VAC operations
  • 24-bit AD/DA, 48k sampling rate
The DS48 loudspeaker management system is a comprehensive sound reinforcement tool that offers 4 input/8 output connectivity, parametric equalizer, crossovers, limiters and time delays. The DS48 can also be controlled from a PC via the DS48's RS232 connection with the included software.
Parametric Equalizer Specifications: • Filter gain: ±12 dB in 1 dB steps • Center frequency: 20 Hz ~ 20 kHz, 31 ISO • Q value: 0.5~10.
Overall Specifications: • Input impedance: 10K ohms • CMRR: 50 dB (30 Hz ~ 20 kHz) • Output impedance: <500 ohms • Maximum output electrical level: Vpp=7.6V • Frequency response: 20 Hz ~ 20 kHz • Dynamic range: 110 dB (A-weighted) • Distortion: 0.01% THD • A/D Processor: AK5392, 24-bit data channel processing; Full 48-bit double-precision mode, 24 bit/48 kHz sample rate • Maximum delay: 7ms (selectable in 0.5 ms increments) • Output gain: -40 dB ~ +6 dB (±0.5 dB) • Input gain: -40 dB ~ +6 dB (±0.5 dB • Power: 110 VAC 60 Hz, 220 VAC 50 Hz • Dimensions: 19" x 1.74" x 8.66" (80 x 44 x 220 mm) • Weight: 8 lbs. (3.6 kg).
  • BrandBBE Sound
  • Part Number246-2326
  • UPC791018482239
  • Product CategorySpeaker Processors / Management Systems
    (1 Reviews)
  • Weight8.9 lbs.
View similar products to the BBE DS48 4-Input 8-Output Loudspeaker Management System
in the Speaker Processors / Management Systems product category.
