BBE BMAX-T Class A Tube Bass Preamp with Sonic Maximizer
Brand:|Model: BMAX-T|Part # 246-2362
The BMAX-T is a tube bass preamp/ processor with a class A, DC regulated tube preamp section which follows in the tradition of the classic tube preamp designs of the 50s and 60s.
  • High voltage (300V) tube front end with hand-picked Groove Tubes 12AX7 tube
  • High-end DI section is transformer-balanced with a genuine Jensen transformer
  • Military-spec PC board
  • 1% metal film resistors
  • Custom-made toroidal power transformer
The BBE BMAX-T is a tube bass preamp/ processor with a class A, DC regulated tube preamp section which follows in the tradition of the classic tube preamp designs of the 50s and 60s.
Specifications: • Frequency response @ Line Out: 15 Hz to 30 kHz ±3 dB • S/N Ratio: 100 dB @ unity • Total Harmonic Distortion (THD): Tube section 1%; Post-tube section <0.02% • Maximum output: +22 dBu • Noise: -77 dBu @ unity gain, eq flat • Input impedance: Passive 1M ohm; Active 100k ohms • Output impedance: Balanced XLR 600 ohms, pin #2 hot or "+"; Unbalanced 1/4" 1K ohms • Interactive EQ: Treble (boost only) 15 dB @ 6 kHz; Mid (cut only) 15 dB @ 300 Hz; Bass (boost only) 15 dB @ 40 Hz • Bright switch: +10 dB @ 10 kHz, eq flat • Para-mids: ±12 dB from 250 Hz to 1 kHz (* 0 dBu=0.775mVrms).
  • BrandBBE Sound
  • ModelBMAX-T
  • Part Number246-2362
  • UPC791018362265
  • Product CategoryGuitar Effects & Modeling Processors
  • Weight9 lbs.
View similar products to the BBE BMAX-T Class A Tube Bass Preamp with Sonic Maximizer
in the Guitar Effects & Modeling Processors product category.
