BBE 482i Sonic Maximizer with Unbalanced Inputs/Outputs
Brand:|Model: 482i|Part # 246-2302
The BBE 482i Sonic Maximizer restores an audio signals natural brilliance and clarity by the use of two primary functions by adjusting a signal’s phase relationships between it’s low, mid and high frequencies and augmenting higher and lower frequencies.
List Price$259.00
You Save31%
$179.99
Part # 246-2302
  • Dual-Mono Sonic Maximizer
  • 4th Generation Processing Engine
  • Independent Lo Contour and Process controls
  • Unbalanced 1/4" Inputs and Outputs
  • Unbalanced RCA Inputs and Outputs
  • Hard-wire bypass
The BBE 482i Sonic Maximizer restores an audio signals natural brilliance and clarity by the use of two primary functions. First it adjusts a signal's phase relationships between it's low, mid and high frequencies while progressively adding longer delay times to lower frequencies, this creates a kind of mirror curve created by the speaker neutralizing its phase distortion. Secondly the Sonic Maximizer augments higher and lower frequencies; loudspeakers tend to be less efficient in their extreme treble and bass ranges. The end result is a dynamic program-driven restoration without the ear fatigue that is normally experienced with the use of equalizers or exciters.
Applications include: Broadcasting, DJ sound reinforcement, mastering, musical instruments, tape duplication, recording, and professional sound reinforcement.
Specifications: • Frequency: Process mode: program controlled; Bypass mode: 10 Hz to 50 kHz, ±0.5 dBu, 10 dBu input • S/N ratio: 112 dB • Total harmonic distortion: Process mode: <0.025%, 20-20 kHz; Bypass mode: <0.002%, 20-20 kHz • Maximum output: +21 dBu • Input impedance: 47K ohms • Output impedance: 1K ohms • Sensitivity: -45 dBu for maximum process • Maximum process: +12 dBu boost at 5 kHz • Lo Contour: +12 dBu adjustment at 50 Hz.
  • BrandBBE Sound
  • Model482i
  • Part Number246-2302
  • UPC791018482109
  • Product CategoryEnhancers / Exciters
  • Weight5.85 lbs.
View similar products to the BBE 482i Sonic Maximizer with Unbalanced Inputs/Outputs
in the Enhancers / Exciters product category.
