Bazooka 12 VAC 3500mA AC Power Supply
Brand:|Part # 129-079
This buyout power supply was designed for use with Bazooka powered subwoofers but may be used with low voltage alarm systems and in other applications.
Part # 129-079
  • Designed for Bazooka powered subwoofers
  • 12 ft. combined cord length
  • Can be used with alarm systems
12V AC power supplies are typically used with low voltage alarm and lighting systems. Save over $24 compared to similar power supplies with this exclusive buyout from Parts Express. Combine this 12 VAC power supply with a bridge rectifier (converting the output to modulated DC) to power elaborate LED installations; the AC output keeps extended length wire-run losses to a minimum. Factory buyout—limited quantities!
Note: Power supply designed for indoor use only.
Specifications: • Input voltage: 120V • AC power output: 12V • Current output: 3500 mA max • Output connector tip: 2.5 mm x 5.5 mm plug, 11 mm length • Combined cord length: 12 ft. • Dimensions: 2-1/4" H x 2-1/2" W x 3-3/8" D.
  • AC Output Voltage12V
  • Current Capacity3500 mA
  • Center/Tip PolarityAC
  • Plug Size2.5 x 5.5 mm
  • Input Voltage120 VAC
  • BrandFactory Buyouts
  • Part Number129-079
  • UPC844632096341
  • Product CategoryAC/DC Power Adapters
    (3 Reviews)
  • Weight2 lbs.
