Battery Powered Bluetooth Wireless Audio Receiver with Power Supply White
Brand:|Model: MB-CM15112|Part # 320-354
Add Bluetooth support to nearly any amplifier, receiver, or car stereo with an audio input using this battery powered Bluetooth receiver. Streams up to 10 meters, compliant with Bluetooth 2.0, and supports A2DP v1.2. Stereo 3.5 mm male-to-male patch cable required.
List Price$29.99
You Save34%
$19.90
Buy 4+$18.48
Part # 320-354
  • Portable battery powered Bluetooth receiver
  • Works with Android smartphones, tablets computers, iPhones, and iPads
  • Stream audio wirelessly from devices up to 33 feet away
  • Bluetooth 2.0 compliant and supports A2DP v1.2
  • Includes power supply and 29.5" USB A Male to USB B mini Male charging cable
Cut the cord on your smartphone, iPod, iPhone, iPad, tablet computer, or laptop and enjoy streaming audio wirelessly (up to 32.8 feet) to your stereo receiver using this battery powered Bluetooth receiver (hands-free phone operation not supported). You can even add Bluetooth functionality to car stereos with a 3.5 mm (1/8") auxiliary input. Also works as a fixed-gain wireless headphone amplifier.
The small receiver fits in the palm of your hand—great for users on the go—and complies with Bluetooth 2.0, as well as A2DP v1.2. A 3.7V, 250 mAh lithium polymer (Lipo) battery is built-in and allows you to stream Bluetooth audio for hours, even when there isn't a readily available power source. A mini USB port is built onto the housing for charging the battery over a computer's USB port or the included 5V 500 mA power supply and included 29.5" USB A male to mini USB B male charging cable.
Pairing is quick and simple: turn on your connecting device's Bluetooth function, set your device to discoverable, turn the Bluetooth receiver on (initially indicated by alternating red and blue flashing LEDs), locate the SF-LY001 on your device and select it, finally enter a PIN of 0000.
The alternating red and blue LEDs will change to a flashing blue LED once connected, and you are ready to start streaming audio. Stereo 3.5 mm male-to-male patch cable or stereo 3.5 mm male to stereo RCA adapter cable required for operation (please see Related Items section on the right for recommendations).
Also available in black
This battery powered Bluetooth receiver is fairly sensitive to audio inputs. If you experience distortion, it is likely caused by overdriving the wireless audio input from the source device (such as a smartphone). If you experience distortion, turn the volume down on the source device from maximum to half volume level. The maximum volume level without distortion will vary by source device.
• Internal battery: 3.7 VDC, 250 mAh lithium polymer
• Output connector: Stereo 3.5 mm (1/8") jack
• Complies with Bluetooth 2.0 standard
• Supports A2DP v1.2
• Maximum distance: 10 meters (32.8 feet) line-of-sight
• Included power supply specifications: 5 VDC, 500 mA
• 29.5" USB A Male to USB B Mini Male cable included
Note:The USB connection on this device is for the charging of the internal battery only. Audio is sent out via the 3.5 mm jack only. The USB cable included is not meant for use as a data cable.
Ground loops can occur (hum or buzzing sound) when used with a grounded (3-prong plug) power source. Please see the Related Items section for the Axxess 3.5 mm ground loop isolator to solve this issue if it occurs.
This device does not support phone call features, it is a receiver only.
  • BrandSure Electronics
  • ModelMB-CM15112
  • Part Number320-354
  • UPC6932564225558
  • Product CategoryBluetooth Receivers & Transmitters
    (31 Reviews)
  • Weight0.25 lbs.
Battery Powered Bluetooth Wireless Audio Receiver with Power Supply White is rated 3.5161 out of 5 by 31.
Rated 5 out of 5 by from Works Great!Best possible? Perhaps not. But for the price? Works great. I bought about six for myself and friends. Everyone very satisfied. Several friends ordered additional units. A great way to make an old receiver more useable.
Date published: 2015-07-27
Rated 5 out of 5 by from Awesome Little DeviceConnected quickly. Reconnects quickly. Sounds great. Haven't fully tested the battery life. Gonna get me another one, or two!
Date published: 2015-04-27
Rated 4 out of 5 by from Awesome product. Awesomer price.Bought this to hook up to my home stereo and job site radio. Pretty good range if you raise it up from behind equipment. No problems so far with my limited use.
Date published: 2015-02-17
Rated 4 out of 5 by from Wireless Audio ReceiverThis is a nifty product if you are looking to LISTEN TO SOUND on your stereo speakers, using your smarthpone, tablet or other bluetooth device as your SOURCE.
Date published: 2014-07-12
Rated 1 out of 5 by from Cons do not out way the Pro'sFirst off, it syncs up fairly easy which was great. But the sound quality is horrible. The first five minuets are tolerable, but after that it seems to goes out of phase and distortion gets worse the longer it's being used. This was music being played from an i pod and an GS4 phone. This might work great for "books on tape" but defiantly not any type of HIFI. I would recommend at least Bluetooth 2.1 or higher
Date published: 2014-06-20
Rated 2 out of 5 by from Sounds Great, Does Not Work for Phone CallsI'm not sure why, but the receiver works great if I am playing music, or streaming a radio station from phone.But it does not work for phone calls. I have not been able to figure out why.
Date published: 2014-04-18
  • 2016-02-07T06:33CST
  • co_hasreviews, tv_0, tr_31
  • loc_en_US, sid_320-354, PRD, sort_mostRecent
Says "for hours" how many hours on the internal battery?
Asked by: Greesmonky
I have run mine 7 hours without issue. No specified time is given.
Answered by: TomI
Date published: 2015-04-14
I need a control unit to source my I-Phone to my stereo receiver, is this the unit?
Asked by: Okwaho
This will allow you to connect to the receiver Via a bluetooth connection and play audio wirelessly.
Answered by: Chrisf
Date published: 2015-04-01
Can I use this device to connect to JBLSpeaker which is without Bluetooth and make it Bluetooth enabled
Asked by: Godfrey1
If the JBL speaker is powered and has a line level input than this will work for that application.
Date published: 2014-11-17
Will this unit drive sound to small (4 inch), unpowered speakers?
Asked by: tsmithbonterra
No, this will not provide power for any speakers. This is designed to be plugged into an amplifier.
Date published: 2014-10-06
Hi Team, can you ship to New Zealand? The product seems to be the right thing for my speaker box project.  thanks for your time.
Asked by: Doubleu
Please contact our sales and customer service for available stock, price and shipping options. sales@parts-express.com or 800-338-0531 x2.
Date published: 2014-09-09
can i run this directly to my car amp and just use my smart phone/etc. as a radio/player?
Asked by: KJohnson
Yes this will work as long as the amp has a 3.5mm input.
Date published: 2014-09-04
  • 2016-02-06T08:01CST
  • co_hasquestionsanswers, tq_16
  • loc_en_US, sid_320-354, PRD, sort_recentQuestionsFirst
Videos
