Battery Powered Bluetooth Wireless Audio Receiver with Power Supply Black
Brand:|Model: MB-CM15112B|Part # 320-355
Add Bluetooth support to nearly any amplifier, receiver, or car stereo with an audio input using this battery powered Bluetooth receiver. Streams up to 10 meters, compliant with Bluetooth 2.0, and supports A2DP v1.2. Stereo 3.5 mm male-to-male patch cable required.
OUT OF STOCK
Due In: 2/29/2016
List Price$29.99
You Save34%
$19.90
Buy 4+$18.48
Part # 320-355
  • Portable battery powered Bluetooth receiver
  • Works with Android smartphones, tablets computers, iPhones, and iPads
  • Stream audio wirelessly from devices up to 33 feet away
  • Bluetooth 2.0 compliant and supports A2DP v1.2
  • Includes power supply and 29.5" USB A Male to USB B mini Male charging cable
Cut the cord on your smartphone, iPod, iPhone, iPad, tablet computer, or laptop and enjoy streaming audio wirelessly (up to 32.8 feet) to your stereo receiver using this battery powered Bluetooth receiver. You can even add Bluetooth functionality to car stereos with a 3.5 mm (1/8") auxiliary input. Also works as a fixed-gain wireless headphone amplifier.
The small receiver fits in the palm of your hand—great for users on the go—and complies with Bluetooth 2.0, as well as A2DP v1.2. A 3.7V, 250 mAh lithium polymer (Lipo) battery is built-in and allows you to stream Bluetooth audio for hours, even when there isn't a readily available power source. A mini USB port is built onto the housing for charging the battery over a computer's USB port or the included 5V 500 mA power supply and included 29.5" USB A male to mini USB B male charging cable.
Pairing is quick and simple: turn on your connecting device's Bluetooth function, set your device to discoverable, turn the Bluetooth receiver on (initially indicated by alternating red and blue flashing LEDs), locate the SF-LY001 on your device and select it, finally enter a PIN of 0000.
The alternating red and blue LEDs will change to a flashing blue LED once connected, and you are ready to start streaming audio. Stereo 3.5 mm male-to-male patch cable or stereo 3.5 mm male to stereo RCA adapter cable required for operation (please see Related Items section on the right for recommendations).
Also available in white!
This battery powered Bluetooth receiver is fairly sensitive to audio input. If you experience distortion, it is likely caused by overdriving the wireless audio input from the source device (such as a smartphone). If you experience distortion, turn the volume down on the source device from maximum to half volume level. The maximum volume level will vary by source device.
• Internal battery: 3.7 VDC, 250 mAh lithium polymer
• Output connector: Stereo 3.5 mm (1/8") jack
• Complies with Bluetooth 2.0 standard
• Supports A2DP v1.2
• Maximum distance: 10 meters (32.8 feet) line-of-sight
• Included power supply specifications: 5 VDC, 500 mA
• 29.5" USB A Male to USB B Mini Male cable included
Note:The USB connection on this device is for the charging of the internal battery only. Audio is sent out via the 3.5 mm jack only. The USB cable included is not meant for use as a data cable.
Ground loops can occur (hum or buzzing sound) when used with a grounded (3-prong plug) power source. Please see the Related Items section for the Axxess 3.5 mm ground loop isolator to solve this issue if it occurs.
This device does not support phone call features, it is a receiver only.
  • BrandSure Electronics
  • ModelMB-CM15112B
  • Part Number320-355
  • UPC6959687300009
  • Product CategoryBluetooth Receivers & Transmitters
    (25 Reviews)
  • Weight0.25 lbs.
Battery Powered Bluetooth Wireless Audio Receiver with Power Supply Black is rated 3.84 out of 5 by 25.
Rated 5 out of 5 by from Works great!!As a custom builder and installer of stereo units in off road vehicles,I am using this reciever connected to an audio amplifier in a utv to stream music from bluetooth devices. I was pleasantly suprised by the sound quality and ease use this provides.I amable to pair to my devises easily and it does not loss the connection.I will be ordering more of these.
Date published: 2015-04-08
Rated 5 out of 5 by from Does the job wellMy wife is a chorus teacher and heard about this product from a co-worker. She uses it to run choral rehearsal from her ipad. I bought one for my work to control the music playing in my youth center when I'm on the stage. It works well in both settings. I used it with an ipod touch.
Date published: 2015-02-24
Rated 5 out of 5 by from Good wireless optionBought three of these had some concern with the paring pin on all of them being the same. Contacted tech support who assured me they will work fine just have to be careful with the pairing. completed installs and they are working perfectly.
Date published: 2015-01-18
Rated 5 out of 5 by from It works great as expected.With easy pairing with my device and the specs of it I am very Satisfied with it...the only thing that I've noticed is the Bluetooth name that appears in my Cell phone is DLink but I managed to make it work.
Date published: 2014-09-10
Rated 4 out of 5 by from Worked right out the boxBought this to stream music from my phone to an external amp in my garage. Worked right out of the box, pairing was very quick. Some BT devices have issues pairing to my phone (iphone 5) but not this item.
Date published: 2014-06-27
Rated 5 out of 5 by from Battery Powered Bluetooth Wireless Audio RecieverThis is great. I tried a couple of Wireless speakers, but they just didn't sound as good as my stereo or my computer speakers. Now I have the best of both worlds. Blue tooth, and great sounds:)
Date published: 2014-05-17
  • 2016-02-08T06:13CST
  • co_hasreviews, tv_0, tr_25
  • loc_en_US, sid_320-355, PRD, sort_mostRecent
I've got a Bluetooth receiver part # 320-35 for my HP168 amp. I have a Galaxy S6 that I use for my games and music. My problem is that when I play games through it I get a really bad delay but not when I play music... I'm only two feet away from. Why?
Asked by: none3
Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531
Answered by: MattW
Date published: 2015-07-24
How many devices can I pair with this one bluetooth device. Looking in making a makeshift drive through movie night and will have several ppl trying to connect. Thanks.
Asked by: Rubio
Answered by: GregT
Date published: 2015-07-13
Is there a 12volt charger available for this unit?
Asked by: dmsearay
We do not currently carry a compatible 12 volt charger.
Answered by: GregT
Date published: 2015-06-05
I'm having a problem getting the receiver to pair to an Avantree Saturn (BT-200X).  I can barely hear the chime when it appears to pair, but I'm not getting any audio through.  A mismatch with the transmitter, or earbuds?  I've been swapping earbuds.
Asked by: harryevan
Answered by: MattW
Date published: 2015-04-09
Is this a mico USB or mini USB charger.  From the photo it is hard to tell.
Asked by: Catherine
This uses a mini USB port for charging.
Date published: 2014-07-15
I purchased one of these about a year ago, I charged it before use as specified and the unit lasted that one charge and ceased to function. No lights when charging or in on position. Is there anything I can do to get it working?
Asked by: NewB
Please contact our tech support for more help with this problem. 800-338-0531, tech@parts-express.com.
Date published: 2015-02-12
  • 2016-02-08T07:03CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_320-355, PRD, sort_recentQuestionsFirst
Videos
