090-465_ALT_0
Banana Plug Red
High current banana plug designed especially for use with larger conductor wire. Will accept up to 12 gauge wire. Screw type compression connection does not require soldering. Long lasting nickel plated brass finish. Oversized 5mm wire entry will accept larger diameter insulated wire.
090-465
Weight: 0.0132 lbs.
IN STOCK
$1.00
Buy 10-99 $0.92
Buy 100-up$0.80
Part # 090-465
Banana Plug Red
High current banana plug designed especially for use with larger conductor wire. Will accept up to 12 gauge wire. Screw type compression connection does not require soldering. Long lasting nickel plated brass finish. Oversized 5 mm wire entry will accept larger diameter insulated wire.
  • Style / TypeSingle
  • Contact PlatingNickel
Banana Plug Red
  • BrandParts Express
  • Part Number090-465
  • UPC844632010309
  • Product CategoryBanana Plugs
    (19 Reviews)
  • Weight0.0132 lbs.
Banana Plug Black
Part # 090-460
View similar products to the Banana Plug Red
in the Banana Plugs product category.
Banana Plug Red
Banana Plug Red is rated 4.5789 out of 5 by 19.
Rated 4 out of 5 by from Small price big performanceThese Banana plugs where priced very low and I didn't t expect the quality of the items I received! These plugs are well made with quality material the 16AWG I used slide right in and clamped down tight. I used these with my Dayton HTP-3 5.1 Home Theater Package w/12" Powered Subwoofer they fit right into the binding post on the speakers and subwoofer amp. The System produced deep rich bass and OK highs. The reason rated performance as 4 and features as 4.5 is because they are silver and not gold plated so I know that I didn't t get optimal performance in addition the hard plastic finish could have been a more grip able and better to the touch rubber finish. Overall I recommend this item as a great purchase that I would make again!
Date published: 2010-12-27
Rated 3 out of 5 by from And now a review of the red oneGee, what I wrote about the black connector applies to the red one also. For less than a buck, you can't go wrong with this connector. It works as advertised. I must say that these don't compare very well to the Pomona 1325, which is similar but a much better design. The Pomona costs a little more ($1.50) but I feel it's worth the extra. I wish Parts-Exrpress would carry Pomona connectors (hint, hint).
Date published: 2010-03-27
Rated 3 out of 5 by from lolI use these for power connections and they work great, normal speaker ones usually have conductive housing which would be disastrous if they shorted and the power supply instantaneously cranked out a few amps.
Date published: 2010-02-18
Rated 5 out of 5 by from PerfectI purchased these plugs to do one thing and they have all performed ecellent for what they are intended to be used for.
Date published: 2010-01-26
Rated 5 out of 5 by from Great valueThese are great to have on hand. Compared to "high end" connectors they surely do not compare. Yet for quick fixes they are great. Keep in mind that the plastic sleeve does is not a conductor, most high end connectors actually are conductive, just a note to keep in mind.
Date published: 2010-01-13
Rated 5 out of 5 by from great productsimple to hook up works great
Date published: 2009-11-13
Banana Plug Red
Customer projects that include: Banana Plug Red
Part # 090-465
Related Products
Customers Also Bought
