091-330_ALT_0
Banana Plug Pair Compression Type
Very high quality gold banana plug set. Knurled barrel and compression nut with floating "slug". The floating "slug" allows tight wire compression without the twisting effect on the wire strands that other compression connectors have.
091-330
Weight: 0.1188 lbs.
IN STOCK
List Price$7.99
You Save50%
$3.98
Buy 10-up$3.50
Part # 091-330
Qty:  PR
Very high quality gold banana plug set. Knurled barrel and compression nut with floating "slug". The floating "slug" allows tight wire compression without the twisting effect on the wire strands that other compression connectors have. Side-entry accepts up to 8 gauge wire while the rear-entry accepts up to 8 gauge wire. Also accepts rear-entry banana plugs for stacking. Overall dimensions: 1-7/8" L x 7/16" W. Sold in pairs: 1-red and 1-black per package.
Instructions: Side entry cable installation: Loosen rear compression screw in counter clockwise fashion to expose side opening on banana plug. Remove approximately 5/16" of insulation from speaker cable. Insert exposed wire (up to 12 AWG) into side opening. Tighten rear compression screw to secure wire. Rear entry cable installation: Remove rear compression screw and compression slug from banana plug. Remove approximately 1/4" of insulation from speaker cable. Insert speaker cable into rear compression screw. Fan wire (up to 8 AWG) and fold conductors over the rear compression screw. Ensure that conductors do not interfere with rear compression screw threads. Insert compression slug first into the banana plug. Install rear compression screw securing cable to banana plug.
  • Style / TypeSingle
  • Contact PlatingGold
  • BrandParts Express
  • Part Number091-330
  • UPC844632017278
  • Product CategoryBanana Plugs
  • Unit of MeasurePR
    (42 Reviews)
  • Weight0.1188 lbs.
View similar products to the Banana Plug Pair Compression Type
in the Banana Plugs product category.
Banana Plug Pair Compression Type is rated 4.7381 out of 5 by 42.
Rated 5 out of 5 by from Easy to use and effectiveI needed some banana plugs to terminate my Mapleshade Golden Helix speaker wire. The wire is a thin solid core and I inserted it through the side port of the banana plugs where I was able to make a secure connection. Using the side ports allowed me to stack the banana plugs from a jumper cable to bi-wire my speakers. Easy to do, effective and inexpensive
Date published: 2014-06-02
Rated 5 out of 5 by from Perfect plugs at a perfect price.Fantastic plugs. I recently purchased a pair of plugs with a screw on the side, and these were better quality at less cost. The simplicity of installation was a charm. Highly recommended. Took me 6 minutes to unpack and attach to the speaker wires. Nice heavy duty plugs that were inexpensive and function perfectly.
Date published: 2014-03-05
Rated 5 out of 5 by from great value for banana connectorsHigh quality and great price. How can you go wrong?
Date published: 2013-10-28
Rated 5 out of 5 by from PlugsEasy to install from side or end. I installed from end.Has high quality performance.
Date published: 2013-10-22
Rated 5 out of 5 by from High quality connectorsVery well made. Easy to use. Accepts large diameter wire such as for home speakers.
Date published: 2013-10-06
Rated 4 out of 5 by from Speaker plugEasy to install and it fits 10g wire with external insulation removed
Date published: 2013-09-17
Could I use these as charging terminals for a 12volt 7amp sla battery using a 12volt trickle charger?
Asked by: Doodle69
Yes they will work although you will want to be careful not to short them together.
Date published: 2014-03-17
Can you install two wires into this connector?
Are these plugs capable of wiring the rear and side simultaneously for bi-wiring?
Asked by: clanderson
Yes you can hook up two separate wires to this banana plug as long as the two combined gauges do not exceed 8 gauge.
Date published: 2013-08-24
How do you install the wire into this connector?
Was just wondering if somebody could clarify how to install the wire into this connector.
You unscrew the read part of the banana plug, insert the wire into the opening on the side and screw it back down.
Date published: 2013-08-09
Customer projects that include: Banana Plug Pair Compression Type
