CLEARANCE
183-322_ALT_0
Balun Push Terminal to BNC Male
Brand:|Part # 183-322
Using push terminal video baluns connected to unshielded twisted pair wire is a low cost option compared to using coaxial cable, with the additional benefit of running four separate video signals over one wire run.
List Price$24.99
Regular Price$18.90
You Save48%
Sale Price
$9.80
Part # 183-322
  • Convert a 75 ohm coax signal to 100 ohm UTP signal
  • Transmits video up to 1,000 ft. over inexpensive Cat 5 cable
  • Connects directly to the BNC connector on a camera or video device
  • Acts as a natural ground loop isolator
  • Allows the transmission of four video signals over one UTP cable
  • Sold individually
Video baluns offer a cost effective way to install surveillance and video systems. Unshielded twisted pair (UTP) cable is less expensive than coaxial cable and generally easier to install due to its smaller diameter and superior flexibility.
You can increase the value of your installation by using Push Terminal to BNC baluns. The push terminal accepts one pair of the UTP cable's four-pair of conductors. Simply remove the jacket from the cable and strip the insulation from the paired conductors. It is best to keep the pairs twisted together, untwisting only about 1/2" for use with the balun.
The Push Terminal to BNC male balun can attach directly to the video output of a camera or video source device and accepts a standard network cable plug. The 75 ohm video signal is converted to a 100 ohm signal to travel over the UTP cable up to 1,000 feet. A second balun is used on the opposite end of the UTP cable to convert the signal back to 75 ohm use. Additionally, since the input and output of a balun are not physically connected, baluns inherently eliminate ground loops' effects on the system. Sold individually, used in pairs.
  • Video Input/OutputComposite (BNC)
  • BrandParts Express
  • Part Number183-322
  • UPC844632093043
  • Product CategoryAudio/Video Extenders over UTP Cat 5e/6 Cable
  • Weight0.045 lbs.
View similar products to the Balun Push Terminal to BNC Male
in the Audio/Video Extenders over UTP Cat 5e/6 Cable product category.
Part # 183-322
